System Verilog Assertion - SVA - All the ones on the data bus should be contiguous
I am trying to write an optimal SVA Assertion to check that all the ones on a data bus are contiguous to one another.
Any advice.
Thanks in advance
In reply to verification_engineer_smart:
Provide an example for your requirements. Also is this for all cycles or do you have an antecedent?
bus 1011110001101   //  pass or fail?
    011111100001010 // ?
    Other           // PASS
    Other           // FAIL
Other           // PASS
Other           // FAIL
101111001101 //fail
000111100000 //pass
000000011111 //pass
000000110001 //fail
// Untested, but it looks OK
   bit[15:0] q;
  function automatic bit contig (bit[15:0] x);
      bit gota1;
      for (int i=0; i<16; i++) begin
        if(!gota1 && x[i]==1'b1) gota1=1'b1;
        else if(gota1 && x[i]==1'b0 ) return 0;
        else if(i==15 && (!gota1 || x[i]==1'b1)) return 1;
   property p_contig;
    bit[15:0] v;
     @ (posedge clk) $rose(a) |-> (1, v=contig(q))  ##0 v;
   ap_contig: assert property(@ (posedge clk) p_contig);
  3. Papers:
Updated
Thanks Ben. Will try and let you know.
Looking at the function again, I believe that
else if(i==15 && (!gota1 || x[i]==1'b1)) return 1; // OK
// But, it can be replaced with
else if(i==15) return 1;
// In other words, the
&& (!gota1 || x[i]==1'b1) seems redundant
… A though, or more a technicality, though adding this redundancy makes the ode more readable.
//untested
//algorithm:
//compare 2 bits at a time such as bit[0] & bit[1] and incrementally keep comparing till
//BUS_WIDTH-1
//when contiguous 1’s are observed raise the start_flag(precondition) then check for bit[i+1] =
//1 bit [i] = 0 pattern which makes it non contiguous. Then the assertion shouts when
//continuous assign gets error in pattern.
bit start_flag, err_flag;
start_flag = 0;
err_flag = 0;
genvar i;
generate
for (i = 0; i < 32; i++) begin
assign start_flag = (bit[i+1] & bit[i]) == 1? 1 : 0;
assign err_flag = (bit[i+1] & !bit[i]) == 1? 1 : 0;
endgenerate
assert_contiguous: assert property( @(posedge clk) disable_iff (rst) start_flag |-> err_flag );
In reply to Geethanand Nagaraj:
The generate is expanded at elaboration not in simulation.
My previous property did not consider the case of a “10” sequence like 000111100000 //pass
The following does it because the loop detects that 10 case, and considers it in evaluating the return value. Hopefully, I was correct in my evaluations.
      bit gota1, gota10;
      for (int i=15; i==0; i--) begin
        case ({i==0, gota10, gota1})
         3'b000: if(x[i]==1'b1) gota1=1'b1;  // new '1'
         3'b001: if(x[i]==1'b0) gota10=1'b1; // there was a 1, new 0
         3'b010: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
         3'b011: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
         3'b100: return 1; // last bit, x==0 -> OK, no error
         3'b101: return 1; // was a 1, NO 10, x==0000000...10 or x==000000...11-> OK
         3'b110: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
                 else return 1; // was a 10, now new 0 -> OK
         3'b111: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
        endcase
        /* if(!gota1 && x[i]==1'b1) gota1=1'b1;
        else if(i==15 && (!gota1 || x[i]==1'b1)) return 1; */
   property p_contig;
    bit[15:0] v;
  3. Papers:
Ben
In the property, can “a” be “clk”?
Also, can you please explain this property, in some detail :
You need to understand the evaluation regions in Svg.
See SVA evaluation - SystemVerilog - Verification Academy
Am using a sequence_match item; the 1 forces the variable v to be equal to the result of the function call. I then continue the evaluation of the consequent. If v==0, then the sequence is a no match and assertion fails.
Ben systemverilog.us
This is a model with lots of debug info.
// import sva_delay_repeat_range_pkg::*;
  timeunit 1ns/100ps;
  `include "uvm_macros.svh"
   import uvm_pkg::*;
   bit clk, a;
   bit[15:0] q;
      bit gota1, gota10;
      $display("%t x= %h", $realtime, x);
      for (int i=15; i>=0; i--) begin
         if(i!=0 && !gota1 && !gota10 && x[i]==1'b1) begin
            $display("i=%d  (i!=0 && !gota1 && !gota10 && x[i]==1'b1 gota1", i); gota1=1'b1; end // new '1'
         if(i!=0 && !gota1 && !gota10 && x[i]==1'b0) begin
            $display("i=%d  (i!=0 && !gota1 && !gota10 && x[i]==1'b0 bull", i);  end // there was a 1, new 0
         if(i!=0 && gota1 && x[i]==1'b0) gota10=1'b1; // there was a 1, new 0
         if(gota10 && x[i]==1'b1) begin
            $display("gota10 && x[i]==1'b1 return 0"); return 0; end // was a 10, now new 1 -> error
         if(i==0 && !gota10)  begin
            $display("i==0 && !gota10) return 1"); return 1; end // last bit, no 10-> OK, no error
         if(i==0 && x[i]==1'b1)
            begin $display("i==0 && x[i]==1'b1) return 0"); return 0; end // was a 10, now new 1 -> error
         if(i==0 && x[i]==1'b0) begin
            $display("i==0 && x[i]==1'b0) return 1"); return 1; end // was a 10, now new 0 -> OK
        /*case ({i==0, gota10, gota1})
         3'b01x: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
         //3'b011: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
         3'b10x: return 1; // last bit, no 10-> OK, no error
         //3'b101: return 1; // was a 1, NO 10, x==0000000...10 or x==000000...11-> OK
         3'b11x: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
         //3'b111: if(x[i]==1'b1) return 0; // was a 10, now new 1 -> error
         //       else return 1; // was a 10, now new 0 -> OK
        endcase*/
   property p_contig;
    bit v;
     @ (posedge clk)  (1, v=contig(q), $display("v=%b", v))  ##0 v;
     // $rose(a) |-> (1, v=contig(q))  ##0 v;
   ap_contig: assert property(@ (posedge clk) p_contig) $display("%t PASS q=%h", $realtime, $sampled(q));
                           else $display("%t FAIL q=%h", $realtime,  $sampled(q));
 // when bit "a" is high then at the next cycle
   // bit [1:0]b ==11 ##1 b==00 ##1  b=11... Continuous,
  // suppose in between a=0 then again whenever 'a' becomes 1 then b value is 11 and then continuous same as above??
   initial forever #10 clk=!clk;
       repeat(20) begin
           @(posedge clk);
           if (!randomize(q, a)  with // a dist {1'b1:=1, 1'b0:=1};
           { q dist {16'b0000111100000000:=1, 16'b0000111100011000:=1};
       }) `uvm_error("MYERR", "This is a randomize error");
       $finish;
  3. Papers:
Ben
q is actually a 4 bit signal and the assertion seems to be failing when q is F, after reset_n is de asserted and then becomes 1 again.
Show us your model.
Also, do you find a fault in the function I wrote?
Ben
In any case, your latest code PASSES now. Thanks a lot for your support.
May be, there was an issue with my environment earlier.
