Checking clock period using system verilog assertion
i have been trying to assert the clock period of clock having frequency 340 MHz using following systemverilog code
realtime clk_period =1000.0/340.0ns;
property T_clk(int clk_period);
time current_time;
disable iff(!RESET_N || !ENABLE)
(('1,current_time=$realtime) |=>(clk_period==$realtime-current_time));
assert_period:assert property (@(posedge clk)T_clk(clk_period))
$warning("%t TB_INFO : clk not correct",$realtime);
assertion gets active with posedge of clk but after next clk edge it shows failed instead of finish.
assertion is failing
what may be the problem and possible solution
The issue here is that the formal argument of the property is of type “int”, yet you’re passing as actual a realtime. Per 1800
“integer_atom_type ::= byte | shortint | int | longint | integer | time
non_integer_type ::= shortreal | real | realtime”
The following code worked OK
module m2b;
	time clk_period =20.0/1.0ns;
	bit clk, RESET_N, ENABLE;
		realtime current_time;
		// disable iff(!RESET_N || !ENABLE)
	   $display("%t TB_INFO : clk  correct",$realtime);
    initial forever #10 clk=!clk;
	  $display("START");
	  repeat(10) @(posedge clk);
	  $finish;
endmodule : m2b
Thanks it was helpful to certain extent
I m not able to keep formal argument of property to real data type
here
time clk_period = 20.0/1.0ns that means clk_period is effectively 20
but how to find for 340 MHz.
time clk_period = 1000.0/340.0ns that means clk period is effectively 2.94…
how to write code for this frequency.
In reply to raghav kumar:
The issue is that you’re dealing with real numbers, thus the “==” is not going to work because of resolution.
You’ll need to specify a range of acceptable accuracy. Below is code that worked, but you need to set the acceptable ranges and timescales, using the timeunit and timeprecision
module m2b;
         timeunit 1ns;     timeprecision 100ps;
	realtime clk_period =1000.0/340.0ns;   // =2.941176470588235
  property T_clk(real clk_period);
		time current_time;
         (clk_period <= $realtime-(current_time-0.001ns))  ||
         (clk_period >= $realtime-(current_time + 0.001ns)));
initial forever #1.470 clk=!clk;
	$display("START");
			// $display("%t %t TB_INFO : clk  correct",$realtime, $realtime);
	$finish;
endmodule : m2b
  • SystemVerilog Assertions Handbook 3rd Edition, 2013 ISBN 878-0-9705394-3-6
thank u it was great help ,now the code is working
replacing || with && and current_time and clk_period should have same data type. :)
I have a question. I’m still learning SVA, and I have not seen the following syntax used in the above example.
Could you tell me what the antecedent part ( (('1,current_time=$realtime) ) means? Thank you.
In reply to jaecho@broadcom:
The ('1,current_time=$realtime) is called a sequence_match_item
sequence_expr ::=  // one of the possibilities is
( sequence_expr {, sequence_match_item }) [ sequence_abbrev ]
sequence_match_item ::=
    operator_assignment
  | inc_or_dec_expression
  | subroutine_call
sequence_abbrev ::= consecutive_repetition
consecutive_repetition ::=
  [* const_or_range_expression ]
In this case, ('1,current_time=$realtime) the '1 is a sequence expression, which means that at every attempt, it will succeed. sequence_match_item are typically used in things like
property p; // if wr, data -> mem, check data is properly written after 4 cycles
  int v_data, v_addr;   // this is a slow memory, or it goes through other paths.
  (wr, v_data=data, v_addr=addr) |-> ##4 mem[v_addr]==mem_data;
Ben Cohen SystemVerilog.us
Thank you for your answer. I could not look for this in LRM, since I did not know what this is called (sequenc_match_item). I do see it now.
BTW, I have your book (SystemVerilog Assertions Handbook) and just getting started with it.
I hope you find the book useful for your projects. Make sure you understand in chapter 1 the section on attempts and threads. Also make sure you understand the needs for the first_match operator. Understanding those concepts can save lots of time. The dictionary of examples is also very useful as it reinforces the uses of the various constructs.
Ben SystemVerilog.us
I am new to system verilog assertions , i have read in the LRM that real data type is not allowed to be passed to property but in the above example of clock
checker it is being passed .
can you help me on this
In reply to SAKET@ KUMAR:
You CAN use real in expressions that result in a Boolean. For example
property preal;
    	real v;
    	(a, v=3.14) |=> v> 4.0;
    ap_real: assert property(@(posedge clk) preal  );
You cannot use real in clock delays or repeat time.
// ILLEGAL
    a ##1.2 b
ok thanks ,it was very helpful
How can we check whether Ton and Toff of the clock are as desired (using SVA)?
In reply to perumallatarun:
See vhttps://verificationacademy.com/forums/systemverilog/checking-clock-using-sva
Hi All,
When I run the above code in VCS I am getting the following error please let me know any switches in the command line to be used. Or if this should be run using specific version of vcs(I am using version 2013 of vcs).
Error-[SVA-ITRHS] Invalid type in local variable assign
clock_generate_assert.sv, 6
clock_assert, “$realtime”
Expressions involving real, realtime, string, event and dynamic
SystemVerilog types including virtual interface references are not allowed
in local variable assignments in properties and sequences.
Regards,
Rajesh.B
In reply to rajeshsois:
This forum is not for tool issues. You will need to contact your vendor directly for support.
clock_assert, "$realtime"
As mentioned, this forum does not address tools. However, it DOES address language issues. Referring to 1800: 16.6 Boolean expressions
/* Assertions that perform checks based on time values should capture these values in the same context. It is not recommended to capture time outside of the assertion. Time should be captured within the assertion using local variables. The following example illustrates how a problem may arise when capturing time in different contexts. In property p1, a time value, t, is captured in a procedural context based on the current value of count. Within the assertion, a comparison is made between the time value t and the time value returned by $realtime in the assertion context based on the sampled value of count. In both contexts,
$realtime returns the current time value. As a result, the comparison between values of time captured in the different contexts yields an inconsistent result. The inconsistency results in the computation for p1 checking the amount of time that elapses between 8 periods of clk instead of the intended 7. In property p2, both time values are captured within the assertion context. This strategy yields a consistent result. */
bit count[2:0];
realtime t;
initial count = 0;
always @(posedge clk) begin
  if (count == 0) t = $realtime; //capture t in a procedural context
  count++;
property p1;
  @(posedge clk)
  count == 7 |-> $realtime – t < 50.5;
property p2;
  realtime l_t;
  @(posedge clk)
  (count == 0, l_t = $realtime) ##1 (count == 7)[->1] |->
                  $realtime – l_t < 50.5;
Thus, realtime and $realtime can be used in assertions. If a tool doe snot abide by those rules, you need to contact the vendor, and quote him that section and example of the LRM.
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
Hi I know this is an old thread, but I’m quite interested in the OP’s assertion code as I’m trying to write clock assertions as well. I have two questions:
  1. In the property, the OP has written this:
What is the '1 at the beginning of the statement for? What does it achieve?
  1. Let’s say I want to pull out the value of $realtime-current_time into an error message if this property catches a failure. Is there a way I can pull out the value of a variable inside a property? If not, what are my options?
Thanks!
In reply to silverace99:
The 1’b1 (a more typical application here) makes the antecedent true, and thus variable in the sequence match item is updated. You can replace the 1’b1 with a variable (e.g., k), but if that variable evaluates to zero, the property is vacuous.
Two solutions: Edit code - EDA Playground
module M;
  bit clk;
  realtime t1, clk_period=20.0;
  initial forever #11 clk=!clk;
  property p2;
   @(posedge clk)
    (clk_period==$realtime-current_time);
  ap2: assert property(p2) else
       $display ("error"); // local variable is not accessible here ******!!!
    function automatic bit check_period(realtime now_time);
      if ($realtime-now_time != clk_period) begin
        t1=$realtime-now_time; // <<<<module variable update here
        return 0;
      else return 1'b1;
    endfunction : check_period
   property p3;
     bit pass;
     @(posedge clk)
     (1, pass=check_period(current_time));
    ap3: assert property(p3);
Another option is to use tasks and do whatever you want. See my recently published paper
Abstract: Understanding the engine behind SVA provides not only a better appreciation and limitations of SVA, but in some situations provide features that cannot be simply implemented with the current definition of SVA. This paper first explains, by example, how a relatively simple assertion example can be written without SVA with the use of SystemVerilog tasks; this provides the basis for understanding the concepts of multithreading and exit of threads upon a condition, such as an error in the assertion. The paper then provides examples that uses computational variables within threads; those variables can cause, in some cases, errors in SVA. The strictly emulation model with tasks solves this issue.
I see. so by pulling all the variables into a function, you’ve moved the variable scope up to a level an error message can access. Very cool. Thanks Ben!
