The issue here is that the formal argument of the property is of type “int”, yet you’re passing as actual a realtime. Per 1800
“integer_atom_type ::= byte | shortint | int | longint | integer | time
non_integer_type ::= shortreal | real | realtime”
The following code worked OK
module m2b;
time clk_period =20.0/1.0ns;
bit clk, RESET_N, ENABLE;
property T_clk(int clk_period);
realtime current_time;
// disable iff(!RESET_N || !ENABLE)
(('1,current_time=$realtime) |=>(clk_period==$realtime-current_time));
assert_period:assert property (@(posedge clk)T_clk(clk_period))
$display("%t TB_INFO : clk correct",$realtime);
else
$warning("%t TB_INFO : clk not correct",$realtime);
initial forever #10 clk=!clk;
$display("START");
repeat(10) @(posedge clk);
$finish;
endmodule : m2b
