module flop
#(parameter width = 1)
(input wire [width-1:0] d,
input wire clk,
input wire rst_n,
output wire [width-1:0] q
bind meta_flop meta_flop_metastability_injector_if i0 (
.meta_ff_d (d),
.dst_clk (clk),
.dst_rst_n (rst_n),
.meta_ff_q (q)
interface meta_flop_metastability_injector_if (
input logic meta_ff_d,
input logic dst_clk,
input logic dst_rst_n,
output logic meta_ff_q
In the code shown above, how do I pass the parameter width to the interface and bind declarations? Thank You!
dave_59
December 24, 2014, 3:39pm
2
When you use bind, all the identifiers you reference in the instantiation are from the target’s perspective, that includes the parameter override.
module flop
input wire clk,
input wire rst_n,
endmodule : flop
typedef logic [7:0] uint8_t;
typedef logic [15:0] uint16_t;
logic clk, rst_n;
uint8_t d8,q8;
uint16_t d16, q16;
flop #(8) u8(.clk, .rst_n, .d(d8), .q(q8));
flop #(16) u16(.clk, .rst_n, .d(d16), .q(q16));
bind flop
meta_flop_metastability_injector_if #(.WIDTH(width)) i0 (
.meta_ff_d (d),
.dst_clk (clk),
.dst_rst_n (rst_n),
.meta_ff_q (q)
endmodule : top
#(parameter WIDTH = 1)(
input logic [WIDTH-1:0] meta_ff_d,
output logic [WIDTH-1:0] meta_ff_q
initial $display("hello from %m WIDTH: %0d",WIDTH);
endinterface : meta_flop_metastability_injector_if
In reply to dave_59 :
Thank You Dave!
I wish you a Merry Christmas and a Happy New Year!
module flop
input wire clk,
input wire rst_n,
endmodule : flop
logic clk, rst_n;
uint8_t d8,q8;
uint16_t d16, q16;
bind flop
.meta_ff_d (d),
.dst_clk (clk),
.dst_rst_n (rst_n),
.meta_ff_q (q)
endmodule : top
Hey Dave,
I have few questions:
What is the advantage of binding the Interface with the DUT?
If I need to add any interface signal during the simulation, is it possible to do using this bind concept?
I’ll be looking forward to your humble response.
Thank you,
Regards,
Muneeb Ulla Shariff
In reply to muneebullashariff :
The bind construct is useful when inserting functionality inside your DUT without modifying your DUT when not practical. This is typically used by monitors and checkers as part of your testbench.
I don’t understood your second question. The bind construct connects to existing signals in your design. You can add whatever signals you want inside the interface.
Hey Dave,
Many thanks for your reply.
Let me explain my question: “If I need to add any interface signal during the simulation, is it possible to do using this bind concept?”
What I mean is, if my interface is as below before simulation starts:
interface int_if ( input logic clk,
input logic data_in,
input logic rst,
output logic data_o
endinterface : int_if
Can I add another input signal, say, logic a_in to the interface in any of the uvm_phases, is it possible to do it?
Thank you,
Regards,
Muneeb Ulla Shariff
No.
module flop
input wire clk,
input wire rst_n,
endmodule : flop
logic clk, rst_n;
uint8_t d8,q8;
uint16_t d16, q16;
bind flop
.meta_ff_d (d),
.dst_clk (clk),
.dst_rst_n (rst_n),
.meta_ff_q (q)
endmodule : top
Bind of the interface does not work when input/output is declared within clocking blocks of interface, like the one below(Thats how my 3rd Party VIP is), How do we then bind?
logic dst_clk,
logic dst_rst_n,
clocking master_synch @(posedge sys_clk);
input [WIDTH-1:0] meta_ff_d,
input dst_clk,
input dst_rst_n,
output [WIDTH-1:0] meta_ff_q
endclocking
In reply to rsguptaji :
Please explain what “does not work” means. I’m guessing you need to declare meta_ff_q as an output wire instead of the default input.
Created the same code in eda playground for the error I am facing.
Edit, save, simulate, synthesize SystemVerilog, Verilog, VHDL and other HDLs from your web browser.
Please suggest when input/output is declared within clocking blocks of interface, then how do we then bind?
dave_59
November 8, 2018, 3:09pm
11
You need to declare directions for your interface ports. They default to inout, which is incompatible with variables. You could also change the ports to wires.
Clocking block directions are not the same as port directions and do not necessarily match. A clocking block input says to sample a signal, yet that signal could still be an output of the interface.
