I am new to RAL and I am running the default uvm_reg_hw_reset_seq in my test. The test is failing for a register with non zero reset value. It is passing for others which have 0 as the reset value. I get an error as follows :
“m_ral_model.xxxx_REG” value read from DUT (0x0000000000000035) does not match mirrored value (0x00000000xxxx0000).
The mirrored value shows 0 instead of 'h35
I can see the read transaction on the bus, i.e. 'h35 being read on the bus but somehow I get the above error. Also in the generated ral model I can see the configured value for this register is correct ('h35)
I am also running uvm_reg_bit_bash_seq and uvm_reg_access_seq sequence which are passing and I can see the transactions on the bus.
What could be the possible reasons for this kind of mismatch only in case of reset seq ?
I already tried applying reset to the model in reset phase of my test but it did not work. I think the default uvm_reg_hw_reset_seq does that implicitly but I did try doing the following in my test but I still see the same error.
I print the read_data and it shows 'h35 without any error and waveforms also show it on the bus correctly.
After dut reset, I also tried using mirror function for only this register’s particular field with value 'h35 as reset value :
p_sequencer.regmodel.get_reg_by_name($sformatf("XXXXXX_REG")).get_field_by_name("XXXX_field").mirror( .status( status ), .check( UVM_CHECK ) );
$display("mirrored data status is %s",status);
I get status as UVM_IS_OK. Not sure why is it throwing an error while running the default seq uvm_reg_hw_reset_seq, what else can i check ?
Where can I check the implementation of the inbuilt uvm ral sequences like uvm_reg_hw_reset_seq ?
I don’t understand what has gone wrong here.
The error comes as follows so I think I might need to check uvm-1.1d implementation of these sequences, where can I get this code ?
UVM_ERROR verilog_src/uvm-1.1d/src/reg/uvm_reg.svh(2889) @ 345000: reporter [RegModel] Register "m_ral_model.xxxxx_REG" value read from DUT (0x0000000000000035) does not match mirrored value (0x00000000xxxx0000)
It’s a little bit curious. But you do not print out the read value. Ypou are printing the status only.
I do not know how big your code is, but is it possible to share your code personally with me?
I’d spend some time to investigate your problem.
You can reach me here christoph@christoph-suehnel.de
