I tried doing only a simple read from only this register after DUT reset in my test like the following
p_sequencer.regmodel.get_reg_by_name(reg_name).read(status,read_data);
I print the read_data and it shows 'h35 without any error and waveforms also show it on the bus correctly.
After dut reset, I also tried using mirror function for only this register’s particular field with value 'h35 as reset value :
p_sequencer.regmodel.get_reg_by_name($sformatf("XXXXXX_REG")).get_field_by_name("XXXX_field").mirror( .status( status ), .check( UVM_CHECK ) );
$display("mirrored data status is %s",status);
I get status as UVM_IS_OK. Not sure why is it throwing an error while running the default seq uvm_reg_hw_reset_seq, what else can i check ?
