Assertion to check if all bits get set atleast once in simulation for a multibit vector
I need help in writing an assertion to check if a given variable in DUT is set atleast once in simulation cycle.
Variable to check : bit [3:0] p_flags;
Conditions:
  1. variable bits might get set or reset at any clock and it is not guaranteed that at the end of simulation will remain at 1.
Thanks in advance for help.
Regards,
Rohit
In reply to rohitk:
// assertion to check if all bits get set atleast once in simulation for a multibit vector
	bit clk, enb=1;
	bit[3:0] fgs; // flags to check
	initial forever #10 clk=!clk;
	property p_flags;
		bit[3:0] v=0;
		enb |-> (1, v=v | fgs)[*1:$] ##0 (v==4'b1111 || enb==0);
		// When enb gets set to 0, another attempt gets started in the Preponed region
	ap: assert property(p_flags) enb=0;
     repeat(200) begin
       @(posedge clk);
       if (!randomize(fgs)  with
       		{$countones(fgs)==1;}
           ) `uvm_error("MYERR", "This is a randomize error")
       $finish;
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
In reply to rohitk:
How about?
  // Assuming default clock & disable
  property p_check_single_bit_to_be_set;
    s_eventually p_flags[0];
  endproperty : p_check_single_bit_to_be_set
  a_p_check_single_bit_to_be_set : assert property (p_check_single_bit_to_be_set) else
    `uvm_error ("SVA", "Bit was never set to 1")
Combine that with a generate loop for scalable bits
Regards
Srini
http://www.verifworks.com
Hi Ben,
Thanks a ton for help, the assertion property is not failing is none of the bits gets set. I modified your constraint to {$countones(fgs)==0;} and no failure get generated.
Regards,
Rohit
In reply to Srini @ CVCblr.com:
Hi Srini,
Thanks for helping, your solution works fine but it always fails in the end if bits gets set to 0. I had to modify it a bit to get it working for my case:
enb |-> s_eventually fgs[0];
enb=0;
$display(“SVA”, “Bit was never set to 1”);
I incorporated this change from Ben’s solution.
This works fine for me but problem is eventually property is not yet supported by all tools AFAIK. Is there any way we can achieve the same without using eventually.
Thanks again for helping me out.
Regards,
Rohit
In reply to rohitk:
OOPS! There are TWO errors in my solution, and one in Srini’s
  1. My solution needs a strong sequence, as a weak sequence would not fail if not completed.
  2. This assertion needs to be fired ONCE. In both of our original solutions, at every clock yo have a new attempt, and some of those later attempts could produce a failure.
Below is a solution that will work for you. I am assuming that during the first 45 time units, the system is being initialized, and after that, you have a go signal. You don’t need this go signal if you want the assertion to be fired once at time 0.
	bit clk, go;
	property p_flags;
		bit[3:0] v=0;
		go |-> strong( (1, v=v | fgs)[*1:$] ##0 (v==4'b1111));
 initial begin // option 1
 	 wait(go);
 	 ap_flags: assert property(p_flags);
 generate for (genvar g_i=0; g_i<4; g_i++)
 	 initial begin  // opton2
       wait(go);
       ap_fgsi: assert property( go |-> s_eventually fgs[g_i]);;
 endgenerate
 	#45 go <= 1'b1;
     repeat(25) begin
       @(posedge clk);
       		  fgs <= 7;
       $finish;
     wait(go);
     ap_fgsbi: assert property( go |-> strong(fgs[g_i][-> 1]) );
 endgenerate
Complete model is at http://SystemVerilog.us/bitset.sv
Results at end of sim
** Error: Assertion error.
Time: 930 ns Started: 50 ns Scope: top.ap_flags File: bitset.sv Line: 15
Time: 930 ns Started: 50 ns Scope: top.genblk1[3].ap_fgsi File: bitset.sv Line: 21
Time: 930 ns Started: 50 ns Scope: top.genblk2[3].ap_fgsbi File: bitset.sv Line: 28
I received an interesting new approach in resolving this assertion:
“I think that it be more efficient to use an always procedure that remembers that a bit has been set and then use an immediate assertion in a final block to check that all bits are set.” Below is code for that assertion. The complete model is at
	bit clk, go;
	bit[3:0] chkfgs;
     always_ff  @(posedge clk)
   	 if(go && fgs[g_i]) chkfgs[g_i] <= 1'b1;
   endgenerate
   // ap_chkfgs: assert final (chkfgs==4'b1111); // Incorrect! see below
   final  ap_chkfgs: assert (chkfgs==4'b1111); // OK
Thanks Ben for help.
OOPS! One more errata!
SHOULD BE
// you do NOT need the 2nd final in
// final  ap_chkfgs: assert final (chkfgs==4'b1111); // superfulous 2nd final
Ben SystemVerilog.us
