Assertion for check SOP signal loss
Hello.
I have interface with SOP and EOP signals.
I would like to write an assertion that will control for loss SOP signal. That is the EOP signal comes again without SOP.
I wrote this design:
sva_sop_loss: assert property (eop |=> !eop throughout ##[*] sop)
else $error(“%m”);
This worked well untill it became necessary to process packets where SOP and EOP signals could arrive at the same time. In such cases, false positives occured.
Than I assumed that $rose(SOP) occurs earlier than EOP and wrote this:
sva_sop_loss: assert property (eop |=> !eop throughout ##[*] $rose(sop))
else $error(“%m”);
But that didn’t work either. In the end I came up with this:
sva_sop_loss: assert property (eop |=> (!eop | sop&eop) throughout ##[*] sop)
else $error(“%m”);
It seems to work, but there are doubts that this approach is correct. How do you think?
In reply to DefaultName:
Your approach looks OK, but I took a different approach with support logic that addresses other cases. specifically, i address the following requirements
  1. if(eop) then an sop has happened
  2. Every sop has its own eop
  3. After an sop no new sop until an eop
See my paper on support logic, the link is in my signature below.
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    bit clk, sop, eop, sop_happen;
    int sop_count, eop_count;
    default clocking @(posedge clk);
    endclocking
    // Support logic to detect the occurence of a sop
    always @(posedge clk) begin
       if(sop) sop_happen<=1'b1;
       if(eop & !sop) sop_happen <= 1'b0;
    // if an eop then sop happened in the past
    ap_eop_with_sop: assert property(eop |-> sop_happen==1);
    // Functions to maintain the counts of sop, eop
    function void inc_sop();
        sop_count=sop_count+1;
    endfunction: inc_sop
    function void inc_eop();
        eop_count=eop_count+1;
    endfunction: inc_eop
    // Every sop has its own eop
    property p_sop_eop;
      int sop_flag;
        (sop, sop_flag=sop_count, inc_sop()) |=> eop[->1] ##0 eop_count==sop_flag;
    // Pass or fail, the eop count is incremented
    ap_sop_eop: assert property(p_sop_eop) inc_eop(); else inc_eop();
      bit v_a, v_b, v_err;
      repeat (200) begin
        @(posedge clk);
        if (!randomize(
                v_a, v_b, v_err
            ) with {
              v_a dist {
                1'b1 := 1,
                1'b0 := 1
              v_b dist {
                1'b1 := 1,
                1'b0 := 2
              v_err dist {
                1'b1 := 1,
                1'b0 := 15
          `uvm_error("MYERR", "This is a randomize error");
        sop <= v_a;
        if (v_err == 0) eop <= v_b;
        else eop <= !v_b;
      $finish;
  2. Free books:
  1. Papers:
    Understanding the SVA Engine,
    Verification Horizons
    Reflections on Users’ Experiences with SVA, part 1
    Reflections on Users’ Experiences with SVA, part 2
    Reflections on Users’ Experiences with SVA - Part II
    SUPPORT LOGIC AND THE ALWAYS PROPERTY
    http://systemverilog.us/vf/support_logic_always.pdf
    SVA Alternative for Complex Assertions
    SVA in a UVM Class-based Environment
    SVA for statistical analysis of a weighted work-conserving prioritized round-robin arbiter.
    https://verificationacademy.com/forums/coverage/sva-statistical-analysis-weighted-work-conserving-prioritized-round-robin-arbiter.
You could add
p_eop_sop_eop: assert property(
          eop |-> sop[->1] ##0 eop[->1]);
Ben
Thanks, Ben
// On this other addition, note that by itself
// it does not address the case of 2 eop, like
//  eop ... eop ... sop ... eop
// It also does not address the case of 2 sop, like
//  sop ... sop ... eop
// My first solutions do adddress thse points.
Ben
You can try this :
//property declaration
property EOP_EOP_SOP(clk,SOP,EOP,valid);
@(negedge clk) ((EOP && !SOP) |=> (!(EOP && valid && !SOP) throughout EOP[->1]));
//property instance
u_EOP_EOP_SOP : assert property (EOP_EOP_SOP(clk_signal,SOP_signal,EOP_signal,valid_signal)) else `uvn_error(“top”,“EOP was set twice without SOP”)
In reply to shaygueta:
  1. Your property looks good, and it addresses some aspects of the requirements.
  1. I get the impression from the original question that the verification engineer did not write a verification plan in English, but instead directly started to write assertions based on his/her understanding of the requirements. I talked about EXPRESSING REQUIREMENTS in my paper
    Reflections on Users’ Experiences with SVA | Verification Horizons - March 2022 | Verification Academy
  2. Using this on-the-fly approach seems, on the surface, to be efficient and fast because one could argue that SVA does a concise job at specifying the requirements. However, that approach may miss many aspects of the requirements. For example, considering this eop/sop design:
  • 4. MESSAGE LENGTH: The eop[->1] seems to ipically knowmply that the message length is not something to be considered. But, shouldn’t it be? Message length is typically known by a sender or a configuration or can be extracted from the serial message itself with support logic.
    That message length is something taht needs to be verified.
    5. EOP WITHOUT SOP: These tags are generally detected or issued by the design. The message contains many flags of interest to be verified, including eop, sop, parity, format, legal targets, etc…
    The above reasons are why it is important to write a verification plan that is reviewed by the verification team. The writing of the assertions is the easy part.
I wanted to write a simple set of basic checks. This checker is intended to contain the loss of sop, eop, val, violation of the minimum and maximum length of the packet, and, if necessary, the loss of ipg. You are probably right, this approach is conceptually wrong and will not be able to cover all requirements. But unfortunately I don’t have a verification team, and I’m a FPGA developer, so I often have to use simple solutions for mediocre verification)
Specifically in this case, I have a very large design containing many IPs, including PHYs and other network modules. For testing, I wrote a package generator that sends packages to the project and compares them at the output. Globally, this allows you to understand that an error has occurred in the project, but in which specific place - not. To determine in which particular place, you really need to draw up a verification plan and do some serious work. But I don’t have skills and time for that) Therefore, I add such primitive checks to some nodes.
You are correct in doing top-level system tests. The assertions do pickup internal errors.
Whoever is paying for this design needs to put more effort into the verification process. One way or another, the cost will be paid whether it be in time, or in-field repair, or lawsuits if the FGPA is in a critical application (like a traffic controller).
Of course, it could even cost you your job … let’s hope not!
If you can assume that the IPs are correct, you could tap off signals from your IPs for use in the assertions.
Best wishes,
Ben
Can we use auxiliary code to solve it
always @(posedge clk)begin
if(sop) _cnt <= _cnt + 1;
if(eop) _cnt <= _cnt - 1;
missing_sop_eop : assert property ((@posedge clk) disable iff(reset) ( 1=> cnt == 0 || cnt == 1 )
`uvm_error(“missing sop_eop”,“missed eop or sop”)
