Unexpected results for Dynamic delay range
Hi All,
I am trying to write a SVA for property_expression : $fell( siga_ ) |-> ##[dyn1:dyn2] seq_exp; // where dyn1 = 3 and dyn2 = 5
Here is my attempt
The seq_exp is checked thrice . Once at time:35 ( after ##dyn1 ) , second at time:45 ( after ##(dyn1+1) ) and 3rd attempt at time:55 ( after ##dyn2 )
However the assertion doesn’t fail at T:55 ( after ##dyn2 ), it rather fails at next clock at T:65 ( due to expression: (vdiff >= 0) being false )
If I were to write $fell( siga_ ) |-> ##[3:5] seq_exp; the assertion fails at T:55 as per expectation.
Any thoughts / suggestions on how the results could match ?
Note: The same issue exists when dyn1 and dyn2 are both 0. The assertion fails at time:15 instead of time:5
In reply to Have_A_Doubt:
It is better if you can post your sva code and the TB(or waveform)to understand what is the issue.
In reply to plin317:
It looks like I need to change the (vdiff>=0, to vdiff>0
sequence dynamic_delay(count);
        int v;
      (count<=0) or ((1, v=count) ##0 (v>0, v=v-1) [*0:$] ##1 v<=0);
    endsequence // dynamic_delay
  sequence dynamic_delay_lohi_sq(d1, d2, sq);
        int v1, vdiff;
          ( (1, v1=d1, vdiff=d2-d1) ##0 dynamic_delay(v1)   ##0
              (vdiff>0, vdiff=vdiff - 1)[*1:$] ##0 sq); // changed from diff>=0
    endsequence
Imade the change in
https://verificationacademy.com/forums/systemverilog/sva-package-dynamic-and-range-delays-and-repeats
Ben@systemverilog.us
Considering that the query is clear to the specific person to whom the question was meant for, I would say I have provided sufficient info.
The edalink provides flexibility to add code as per requirement so you are free to do that.
Ben ,
I believe the expression ( vdiff >= 0 ) is required for scenarios where dyn1 == dyn2.
Due to (vdiff >= 0) the subsequent sequence is evaluated at same time as dynamic_delay(dyn1) completes.
In your edalink using ( vdiff>0 ), if I were to provide stimulus as :
   d1 = 0 ; d2 = 0 ;
   #4 ; siga_ = 0; data1 = 0 ; data2 = 0;
   #82; $finish();
Instead of assertion pass at T:5 the assertion fails due to (vdiff>0) being false
Whereas if we use (vdiff>=0) the assertion passes at T:5 as per expectations
One possible solution which works as per intention ( for 6 scenarios that I tested ) : edalink
However the code has a limitation ( lack of sufficient clock ticks for RHS of ‘within’ to match ) as observed for +define+M7.
For +define+M7 even if there are sufficient clock ticks the assertion passes at time:55 instead of the expectation at time:35.
Using ‘within’ in consequent the code only works if I write RHS sequence of ‘within’ as 1[*(dyn1+1):(dyn2+1)] ( Tested for all 7 scenarios )
Now the challenge is to code RHS sequence which is dynamic repeat range: 1[*(dyn1+1):(dyn2+1)]
Any alternate solution possible ?
Thanks again for checking my papers and assertions.
I am still human (can make mistakes :)
I fixed the dynamic delays with the following and that works
I updated te package
        int v;
        int v1, vdiff;
    dynamic_delay(d1)   ##0
    ((1, vdiff=d2-d1) ##0 (vdiff>0, vdiff=vdiff - 1)[*1:$] ##0 sq) or
    (d2-d1==0 ##0 sq); // was  (vdiff>=0,
  endsequence
  sequence dynamic_delay_fm_lohi_sq (d1, d2, sq);
        int v1, vdiff;
       (first_match((1, vdiff=d2-d1) ##0 (vdiff>0, vdiff=vdiff - 1)[*1:$] ##0 sq)) or
  endsequence
Ben,
The new code has a limitation when subsequent seq. matches after ##dyn2 clocks
On trying following stimulus :
   $dumpfile("dump.vcd"); $dumpvars;
   d1 = 0 ; d2 = 1 ;
   #4 ; siga_ = 0;
   #10 ; data1 = 0 ; data2 = 0;  // ( data1 == data2 ) at time:15
   #82; $finish();
The expectation is assertion pass at time:15 however the assertion fails at time:15
For : seq1 |-> ##[dyn1:dyn2] seq2; // where dyn1 = 0 , dyn2 = 1
The new code doesn’t evaluate seq2 for 2nd time at time:15 since expression (vdiff>0) is false for ( vdiff > 0 , vdiff-- )[*2:$]
So a solution would be to manually evaluate ‘seq2’ at next clock only if vdiff is 0 after decrement operation i.e LHS sequence of ‘or’ operator should be :
( (vdiff>0, vdiff=vdiff - 1 )[*1:$] ##0( sq or ( (vdiff == 0) ##1 sq ) ) )
For dyn1 = 0 and dyn2 = 1 , seq2 must be evaluated twice. Once after dynamic_delay(0) matches and for 2nd time at next clock after that.
Using the new code ‘vdiff’ is decremented to 0 at same clock that dynamic_delay(0) matches.
Due to repetition range[*1:$] at next clock (vdiff>0) would be false.
With the additional logic ‘seq2’ is evaluated at next clock only if vdiff is 0 for current iteration
I tested the same for 11 scenarios : https://www.edaplayground.com/x/NY55
The code works as per expectations !!
Thanks for pointing it the error. How about this instead?
        int v1, vdiff;
    dynamic_delay(d1)##0
    (sq or
    (1, vdiff=d2-d1) ##0 (vdiff>0, vdiff=vdiff - 1)[*1:$] ##1 sq);
  endsequence
for d1==0, d2=2
you delay for d1 cycles, then you evaluate
(sq or
if diff>0 (2 in this case) you get ##1 sq (vdiff==1), then ##1 sq (vdiff==0)
you end up with
##d1 (sq or ##1 sq ##1 sq
Works as per expectation for all 11 scenarios.
One last question :
For the 4 dynamic scenarios ( delay/delay range/repetition/repetition range) is it assumed that the dynamic variables remain constant for a SVA attempt OR can they change during an ongoing attempt ?
To model these dynamic cases wouldn’t the best approach be to capture the dynamic variables during the start of an attempt itself ?
Yes on need to capture d1, d2 at the start of the evaluation of the sequence.
This fixes it.
    int v1, vdiff;
    (dynamic_delay(d1)##0 sq) or
    (((d2-d1) >0, vdiff=d2-d1) ##0 dynamic_delay(d1)##0
    endsequence
    // New version 11/22/23
    /*sequence dynamic_delay_lohi_sq(d1, d2, sq);
        int v1, vdiff;
    endsequence*/
    /* sequence dynamic_delay_fm_lohi_sq(d1, d2, sq);
            int v1, vdiff;
             first_match( (1, v1=d1, vdiff=d2-d1) ##0 dynamic_delay(v1)   ##0
                  (vdiff>0, vdiff=vdiff - 1)[*1:$] ##0 sq); // was  (vdiff>=0,
    endsequence // dynamic_delay_fm_lohi_sq */
    //New 11/25/23
    int v1, vdiff;
                           first_match((vdiff>0, vdiff=vdiff - 1)[*1:$] ##1 sq));
    endsequence
Ben
Hi Ben,
Seems like the package update to sequence ‘dynamic_delay_lohi_sq’ has been lost post the website update.
I see it in
    // ******       DYNAMIC DELAY RANGE ##[d1:d2] **********
    // Implements     ##[d1:d2] ##0 a_sequence
    // for use in consequent
    // Application:  $rose(a)  |-> dynamic_delay_lohi_sq(d1, d2, q) ;
        int v1, vdiff;
              (vdiff>=0, vdiff=vdiff - 1)[*1:$] ##0 sq);
    endsequence
Ben,
As we discussed at the top of this thread, sequence ‘dynamic_delay_lohi_sq’ has a limitation when sub-sequent sequence doesn’t match even after ##(dyn_max). The assertion fails at next clock rather than ##(dyn_max)'th clock.
Refer edalink +define+M4.
Instead of failure at T:55 the assertion fails at T:65 due to repeat sequence ending.
Your later suggested the following ::
        int v1, vdiff;
    (sq or
  endsequence
which works for all scenarios.
The same was updated in sva-package-for-dynamic-delays in Nov 2023 but that update has been lost ever since the forum upgrade.
First, many thanks for your posts testing 1800 and my code.
I updated the package at
The package has been updated and is now uploaded here and is also avaliable at
https://systemverilog.us/vf/sva_repeat_delay_thru_pkg_011624.sv
Thanks again,
https://systemverilog.us/vf/Cohen_Links_to_papers_books.pdf
