module m_rose;
bit clk, a, b;
bit[3:0] delay=6;
int cycle=0;
let VACUOUSOFF = 11; // assertion control type
$assertpasson(0);
$assertcontrol( VACUOUSOFF); //
always @(posedge clk) cycle <= cycle +1'b1;
initial forever #10 clk=!clk;
// I want to check b rose 6 cycle after a raises,
// and during 6 cycle b should be zero, should not toggle.
property p_delay;
int v;
($rose(a), v=delay+1'b1, $display("Cycle=%d, START, time=%t, DELAY= %d", cycle, $time, delay)) |->
(v>0 && !b, v=v-1'b1)[*0:$] ##1 v==0 ##0 $rose(b);
ap_delay: assert property(p_delay) $display("Cycle=%d, PASS", $sampled(cycle));
else $display("Cycle=%d, FAIL", $sampled(c
ncsim: *E,MSSYSTF (./test_2.sv,8|14): User Defined system task or function ($assertpasson) registered during elaboration and used within the simulation has not been registered during simulation.
I am getting above error.
In reply to tirumalrao_m:
This forum’s emphasis in on language usage and purposely avoids addressing tool issues, as those should be addressed directly with the vendor.
On this particular note, my guess is that the simulator was commanded (or started) into an optimized mode versus a debug mode. You typically do not want to slow the simulator with lots of messages, particularly on PASSONs.
Ben Cohen http://www.systemverilog.us/
SystemVerilog Assertions Handbook 4th Edition, 2016 ISBN 978-1518681448
Seems interesting topic. Is there any simple way to check signal pipeline variable delay. let’s consider 2 signals x1 and x2. Here x2 is delayed version on x1 and this delay is programmable with some variable. I don’t want to check value or state of x2 based on change on x1 because it may possible that x2 follows all transaction on x1 but there are also unexpected transaction x2 that are not there on x1 those transition also needs to be reported as error.
You need to first clarify your requirements about the relationships between x1 and x2.
x2 always follows x1 // Normal behavior
2 occurrences of x2 after x1 // Error behavior
Other relationships
Once this is done, you can easily write assertions. Understand your requirements!
Ben Cohen SystemVerilog.us
In reply to Digesh:
Other relationships
x2 always follows x1 is normal condition. 2 transition on x1 before they reach x2 is also normal condition in such condition you should expect same 2 transition on x2. Now if you think of error behavior it can be like you said 2 occurrences of x2 after x1 other error condition I think of are :
transition on x2 only
transition on x1 only
n number of transition on x1 but m transition on x2 where (m !== n)
Please let me know if you are having hard time understanding my point. I can draw some diagram that way you it will be easy for you to understand me.
I’ll give you guidelines in writing the needed assertions.
FOR “n number of transition on x1 but m transition on x2 where (m !== n)”, you can use the module variables int ticket, now_serving as the difference should be zero at the end of simulation, or at times determined by you.
FOR “2 occurrences of x2 after x1 // Error behavior”. Use something like rose(x1) |-> strong(x2[->1] ##1 !x2[*0:] ##1 $rose(x1));
BTW, this is in conflict with your first requirement “2 transition on x1 before they reach x2”
Hi Ben ,
Thanks for reply I have already implemented this check as per below.
always @(signal1)begin
sig1_cnt = sig1_cnt + 1;
always @(signal2)begin
sig2_cnt = sig2_cnt + 1;
final begin
if(enable_condition)begin
CNT_CHK: assert (sig1_cnt == sig2_cnt) else $display(“sig1_cnt:%d and sig2_cnt:%d count mismatch”,sig1_cnt,sig2_cnt);
Let me know if you think of any better solution than this.
You need to build a testbench for the assertions and see if it meets your requirements.
As you may have noticed, I typically use the randomize with weighted distributions to generate the test signals. For example:
module m;
bit clk, a, din;
repeat(200) begin
@(posedge clk);
if (!randomize(a, din) with
{ a dist {1'b1:=1, 1'b0:=3};
din dist {1'b1:=1, 1'b0:=2};
$finish;
In my 4th edition of the SVA book, I have a chapter thta addresses building a testbench for assertions, and explain the use of typical constraints.
What if the requirement is to pass a range of delay as input variables? For example in the following assertion
$rose (sigA) |-> ##[min_cycle_response:max_cycle_response] ($fell(sigB)) ;
passing delay as parameters from the module seem to work. Is there another way or are there any disadvantage using parameter instead of input ?
If the 2 ranges (min and max) are small, you can use the generate with 2 loops that will create multiple assertions. You can also use a property with local variables; that can be tricky, but the following looks OK to me.
module m5067;
parameter N=0; // <--- Parameter, used for testing a simple assertion
bit clk, a, b, c;
bit[2:0] v=3, v0=0, v1=3;
// ap_range: assert property($rose(a) |-> ##[v0:v1] b); // WANT
ap_range_fix: assert property($rose(a) |-> ##[N:3] b); // Simple, fixd range
property p_range_equivalent; // Equivalent implementation
// Range defined by module variables v0 and v1
int lv0, lv1; // this is an internal local variable defined by the tool
($rose(a), lv0=v0, lv1=v1 )
##0 first_match((1'b1, lv0=lv0-1'b1, lv1=lv1- 1'b1) [*0:$] ##1 lv0<=0)
##0 first_match( (1, lv1=lv1- 1'b1)[*0:$] ##1 (b || lv1<=0))
##0 b;
ap_range_equivalent: assert property(p_range_equivalent);
initial begin // Testing of assertions
repeat(200) begin
@(posedge clk);
#1 if (!randomize(a, b, c) with
{ a dist {1'b1:=1, 1'b0:=5};
b dist {1'b1:=10, 1'b0:=4};
c dist {1'b1:=3, 1'b0:=1};})
$finish;
// 1) Following assertion can never fail because if the *0:$] and b==0
($rose(a), v=delay+1'b1) |-> (v>0, v=v-1'b1)[*0:$] ##1 v==0 ##0 b == 1;
// 2) Following assertion CAN fail because of the first_match() if b==0
first_match((v>0, v=v-1'b1)[*0:$] ##1 v==0) ##0 b == 1;
// 3) Consider the following example
int v=5;
ap_1: assert property( x|-> ##2 b ##v c); // illegal in 1800'2012
/* If the variable used to define the delay has values that are within a constraint
range, such as between 0 and 7 (or 15, or at most 32) one can use the generate statement, which appears much simpler than the use of local variables and the sequence_match_item. Example: */
generate for (genvar g_i=0; g_i<8; g_i++) begin
ap_delay_gen: assert property (v==g_i && $rose(a) |-> ##g_i b);
end endgenerate
// 4) When a parameter is used, the value is static (and does not change) after elaboration, prior to sim.
I am a big fan of you. Your way of solving problems via SVA is amazing. I have a question:
If the variable delay can be achieved by passing parameters then why do we need to do this lengthy workaround?
In reply to muneebullashariff:
Parameters work because they are static after elaboration.
I am not trying to stop you from asking questions, but one good advice that was given to me was to test certain theories or problems to better understand the legality of code.
You your specific question on parameters, see my example at
You your specific question on parameters, see my example at Edit code - EDA Playground
Thanks for being a “fan”
Ben Cohen http://www.systemverilog.us/ben@systemverilog.us
In what scenarios do we need to use parameterized delays and when do we need to use this variable delay (workaround)?
Parameterized delays or repeat operators are typically used when configurations or modes can change prior to a simulation run, but are stable (no change) during the simulation. Modes can be things like low/hi power mode (affects response times), Design A vs Design B (e.g., fast or slow multiplier or IP), interface spec changes (may affect when expected information is received).
Dynamic variable that define delays, though not often used, can be used as a substitute for parameterized delays when within a simulation run one may want to test different configurations or modes. Another example may be when the testbench informs the test interface the length of a message; this is done as a setup prior to the transmission or receipt of the message. The assertion can then may use of the value of that variable to adjust for the verification process.
