In reply to muneebullashariff:
In what scenarios do we need to use parameterized delays and when do we need to use this variable delay (workaround)?
- Parameterized delays or repeat operators are typically used when configurations or modes can change prior to a simulation run, but are stable (no change) during the simulation. Modes can be things like low/hi power mode (affects response times), Design A vs Design B (e.g., fast or slow multiplier or IP), interface spec changes (may affect when expected information is received).
- Dynamic variable that define delays, though not often used, can be used as a substitute for parameterized delays when within a simulation run one may want to test different configurations or modes. Another example may be when the testbench informs the test interface the length of a message; this is done as a setup prior to the transmission or receipt of the message. The assertion can then may use of the value of that variable to adjust for the verification process.
