Is there any constraint to do this.
I would do something like;
constraint c { data == (7’b1111111 << N ); }
And constrain N to keep the shift inside the range of data.
I would try this
rand bit [31:0] data;
rand bit n,m ;
constraint c{ data[n:m]== 7'd127; }
constraint range { n <=31 ; n>=7 ; m == n-7 ; }
In reply to Shilton_uday:
data[n:m] where n and m are variables is not legal SystemVerilog syntax
I tried following code but I am seeing an issue .
Code
class mem_seq_item extends uvm_sequence_item;
//Control Information
rand bit N;
//Utility and Field macros,
uvm_object_utils_begin(mem_seq_item) uvm_field_int(data,UVM_ALL_ON)
uvm_field_int(N,UVM_ALL_ON) uvm_object_utils_end
//Constructor
function new(string name = “mem_seq_item”);
super.new(name);
//constaint, to generate any one among write and read
constraint addr_1_range { N inside {[31:0]}; }
//Simple TestBench to access sequence item
module seq_item_tb;
//instance
mem_seq_item seq_item_0;
//create method
seq_item_0 = mem_seq_item::type_id::create(“seq_item_0”);
seq_item_0.randomize(); //randomizing the seq_item
seq_item_0.print(); //printing the seq_item_0
output
Error-[SE] Syntax error
“testbench.sv”, 23: token is ‘\037777777742’
constraint c { data == (7\037777777742\037777777600\037777777631b1111111
<< N ); }
In reply to ritheshraj:
I try it too.
class Ctrans;
rand bit[31:0] data;
rand int N;
constraint c{data==(7'b1111111 << N);
N<32-7;N>=0;}
module test_top;
Ctrans trans;
trans=new();
trans.randomize();
$display("%b",trans.data);
This is right.The message printed is “00000000000001111111100000000000”.
I think your constraint of N should be :
N inside {[0:31-7]}
or:
constraint c_data{N inside {[0:31-7]};}
data[N+:7]=7'b1111111;
The code bellow is wrong:
constraint c_data{N inside {[0:31-7]};data[N+:7]==7'b1111111;}
In reply to cainiaoma:
Can someone please explain how this constraint works and generates 7 consecutive ‘ones’.
class Ctrans;
rand int N;
N<32-7;N>=0;}
In reply to sriharifoxtrot:
See 11.4.10 Shift operators in the 1800-2017 LRM. Then think about the result of that operations for each value of N between 0 and 25.
class Ctrans;
rand int N;
N<32-7;N>=0;}
Understood operators :). Thank you!
