Anyone familiar with formally verification of
always @(*)
as in doing
assert()
for
always @(*)
along side with
for
loop
always @(*)
as in doing
assert()
for
always @(*)
along side with
for
loop
In reply to feiphung:
What is your question?
How to do assert(logic) inside a ‘for’ loop inside always@(*) block ?
I suppose it is easier to do assert() without ‘for’ loop OR inside always@(posedge clk) block
I don’t see the issue here.
module m;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit clk;
bit[3:0] a=4, b=5, c;
initial forever #10 clk=!clk;
always_comb begin
for (int i=0; i<=3; i++) begin
assert(a[i] > b[i]) else $display("i a[i] b[i]", i, a[i], b[i]);
ap_ab: assert property(@ (posedge clk) a[i] |=> b[i]);
repeat(20) begin
@(posedge clk);
if (!randomize(a, b) with
{ a dist {1'b1:=1, 1'b0:=1};
b dist {1'b1:=1, 1'b0:=2};
}) `uvm_error("MYERR", "This is a randomize error");
$finish;
# KERNEL: i a[i] b[i] 100
# KERNEL: i a[i] b[i] 200
# KERNEL: i a[i] b[i] 300
# KERNEL: i a[i] b[i] 000
# ASSERT: Error: ASRT_0005 testbench.sv(10): Assertion "ap_ab" FAILED at time: 50ns (3 clk), scope: m, start-time: 30ns (2 clk)
# ASSERT: Error: ASRT_0005 testbench.sv(10): Assertion "ap_ab" FAILED at time: 70ns (4 clk), scope: m, start-time: 50ns (3 clk)
I am new to UVM.
I do not know what your uvm code is trying to achieve.
Could you write a few lines of comments on the UVM code itself ?
pm the above example i only used the UVM messenging with severity levels’ there is a lot lot more to uvm. The Universal Verification Methodology (UVM) Class Reference addresses verification complexity and interoperability within companies and throughout the electronics industry for both novice and advanced teams while also providing consistency. UVM has claimed wide acceptance in the verification methodology of advanced designs. For the reporting of messages, UVM provides several macros that resemble the SystemVerilog severity levels, but provide more options and consistency with the UVM verification environment.
Ben
What are the two assert() inside always_comb block trying to achieve ?
you need to study the types of assertions.
Once the always_comb is triggered becuase of a change in any of the signals inside that construct, the
assert(a[i] > b[i]) else $display(“i a[i] b[i]”, i, a[i], b[i]);
is an immediate asn and checks he conditions described on the asn.
Also, the concurrent asd is triggered and at then next posedge of clk, the sampled variables are checked. In this case, if a[i] is true, then at the nect clk cycle b[i] must be true.
There is a lot more to assertions, and you need to study the SystemVerilog assertions described in 1800’17 chapter 16. Of course, my SVA book expands on SVA with lots of examples and text using knowledge got thru experience of 4 authors and providing examples of issues addressed by users on this forum.
I am quite confused with your UVM example.
Maybe let me rephrase my question to a simple test case below:
What assert(logic) could be used for the following always @(*) block ?
module test_assert
input clk,
output done
// a list of 8 integers
localparam MAX_VALUE = 10;
localparam NUM_OF_ITEMS = 8;
reg [$clog2(MAX_VALUE)-1:0] number_list [NUM_OF_ITEMS-1:0];
generate
genvar list_index;
for(list_index=0; list_index<NUM_OF_ITEMS; list_index=list_index+1)
begin: assign_number_to_list
always @(posedge clk)
number_list[list_index] <= list_index; // a list that contains {1,2,3,4,5,6,7,8}
endgenerate
// we have 2,4,6 as even integer
// we have 1,3,5,7 as odd integer
reg [$clog2(NUM_OF_ITEMS)-1:0] num_of_evens_minus_num_of_odds;
integer index;
always @(*)
num_of_evens_minus_num_of_odds <= 0;
for(index=0; index<NUM_OF_ITEMS; index=index+1)
begin: computation_logic
if((number_list[index] % 2) == 0) // even integer
num_of_evens_minus_num_of_odds <= num_of_evens_minus_num_of_odds + 1;
else num_of_evens_minus_num_of_odds <= num_of_evens_minus_num_of_odds - 1;
always @(posedge clk) done <= 1; // the always @(*) will finish in 1 clock cycle
No one can write an assertion without knowing the requirement it needs to verify. If you tell us that, we might be able to show you the code to implement it. If you show us an assertion we might be able to tell you what requirement it was written to verify. So far I’ve seen neither.
Also, the `uvm_error in Ben’s example was a distraction. This of using $display or $error instead. That is all it is doing.
