In reply to Vinay Jain:
This is a big debate. Although it may seam easier to use ‘randomize with’, it does not always scale to the ‘OOP’ way of doing things because it becomes difficult to extend procedural code. If you really want packets of a particular cmd, you should extend the packet class with the additional constraints
class packet_cmd0 extends packet;
`uvm_object_utils(packet_cmd0;
constraint cmd0 {cmd == 0;}
Then create this class instead of the packet class.
