In reply to Reuben:
// Set the item
this.pkt.randomize();
this.pkt.cmd = 1'b0;
With above code I understand you are overriding randmized packet and send the packet as read packing by changing cmd =0.
I believe, here your expectation is to the get pkt where cmd = 0 and data = {td,addr_inc, num_rd}; i.e randomized packet with read attribute if so, please try this one
// Set the item
this.pkt.cmd.rand_mode(0);
With this, it will always generate the read packet with as per your defined construct.
I am not sure, is this what you expecting here!
