In reply to leya:
OK, the following works, I had 26 passes and 3 failures.
property p_clk_freq2;
            realtime current_time;
            @ (posedge clk)
            // disable iff ( !(!(reset) && (flag)))
            ('1, current_time = $realtime) |=> (1, $display ("p=%t", $realtime - current_time))
           // (clk_period <= ($realtime - (current_time-0.001ns))||
           //                 ($realtime - (current_time+0.001ns)));
            // 11.4.13 Set membership operator
            // inside_expression ::= expression inside { open_range_list }
            //int a, b, c;
            // if ( a inside {b, c} ) ...
            ##0  ($realtime - current_time) <= clk_period + 1ns and
            ($realtime - current_time) >= clk_period - 1ns;
        ap_clk_freq2: assert property (p_clk_freq2);
I have to analyze why the solution with the  inside fails.
Below is my Testbench code.
    timeunit 1ns;     timeprecision 100ps;
    bit clk, clk2, a, b;
    realtime clk_period= 20ns;
        initial forever #(clk_period/2 + a*1ns -b*1ns) clk=!clk;
        initial forever  #10ns clk2=!clk2;
            $timeformat(-9, 1, "ns", 8);
            $display("%t", $realtime);
        property p_clk_freq;
            @ (posedge clk)
            //int a, b, c;
            ($realtime - current_time) inside {clk_period - 0.2ns, clk_period + 0.2ns}
        ap_clk_freq: assert property (p_clk_freq);
            @ (posedge clk)
            //int a, b, c;
            bit va, vb;
            repeat(200) begin
                @(posedge clk);
                if (!randomize(va, vb)  with
                { va dist {1'b1:=1, 1'b0:=3};
                vb dist {1'b1:=1, 1'b0:=3};
            a <= va;
            b <= vb;
        $stop;
See Paper: 1)  VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
2)  http://systemverilog.us/vf/SolvingComplexUsersAssertions.pdf
