Assertion for counting clock cycles during reset pulse
I would like to implement a SystemVerilog assertion to check the following:
The clk must be active for at least two cycles during the assertion to zero of the reset signal.
I pasted my current solution below, but it is using an auxiliary fast clk, and has many limitations (including the ratio between the clk and the fast clk).
I was thinking about using variables inside of the property, but don’t know how to check for the number of clock pulses once the reset is deasserted.
My current solution:
  sequence RESET_ASSERTED_THEN_RELEASED;
      (!reset)[*1:$] ##1 reset;
  endsequence
  sequence CLK_PULSE;
      !clk ##[1:20] clk[*1:20] ##[1:20] !clk;
  endsequence
 CLK_ACTIVE_DURING_RESET: assert property(@(posedge fastclk)
      ($past(reset) == 1'b1 && reset == 1'b0 |-> (CLK_PULSE ##1 CLK_PULSE) within (RESET_ASSERTED_THEN_RELEASED))
  else $error("ERROR - clk didn't run at least 2 cycles after the assertion of reset (at %d)", $time);
I’m also experimenting with something like this, but not sure if it is the right direction:
  property count_cycles;
    int cnt;
    ($fell(reset), cnt = 0 )|-> (CLK_PULSE, ++cnt) [*0:$] ##1 (reset, $display("cnt:%d", cnt));
Can this be solved without using an auxiliary faster clock?
If not, do you have any tips how could I make my assertion more simple and efficient?
Thanks in advance.
In reply to spoiled rabbit:
// Comment on your solution
// Add the fast clk
// You can add an test
let n=20;  // Am guessing at the 20, need to specify
    int cnt;
    @(posedge fastclk) ($fell(reset), cnt = 0 )|=>
        first_match( (CLK_PULSE, ++cnt) [*0:$]
                      ##1 (reset, $display("cnt:%d", cnt)))
                     ##0 cnt >= n;
Yes, by using fork-joine_none. Basically, you fire 2 tasks: a 2-clock task and a timeout task. If timeout, then failure. See my paper Understanding the SVA Engine, link below. Note that an assertion can be expressed in many forms; SVA is one way.
    bit clk, reset;
    let period=10ns;
    initial forever #5 clk=!clk;
    // <<<<<<<<<<<<<SEE my response for the correction >>>
    always @(posedge clk)  begin : b0  // SEE BELOW, THIS IS IN ERROR
    // Should be
    //  always @(negedge reset)  begin : b0
      bit got_2clk, done;
      if($fell(reset, @(posedge clk))) // IN ERROR, comment this out
       begin  : fall_reset
          begin : one
            repeat(2) @(posedge clk);
            got_2clk=1'b1;
            done=1'b1;
          end  : one
          begin : two
            #(period*2 +1);
            done=1'b1;
          end : two
        join_none
        wait(done);
        a_2clk: assert(got_2clk); // 2clk is active
        got_2clk=1'b0;
        done=1'b0;
      end : fall_reset
    end  : b0
       #100;
       $finish;
  3. Papers:
Hi Ben,
Thanks for your reply.
I played around with your implementation but if I made no mistake, then it can’t catch that scenario when the reset gates the clk immediately: https://www.edaplayground.com/x/859J (I hope EDA Playground links are allowed)
This solution is dependent on the clk so it is supposed to ‘check itself’ somehow - that’s why I thought that it can’t be solved without an auxiliary clk.
Apologies for my mistake; it always helps to test the code :)
The concept is correct. Below is code that works OK.
Instead of detecting a $fell that relies on the clock, I used
/* https://verificationacademy.com/forums/systemverilog/assertion-counting-clock-cycles-during-reset-pulse */
    bit clk, reset;
    let period=10ns;
    event eclk, eanalog;
    $dumpfile("dump.vcd"); $dumpvars;
      #0  reset = 1;
      #100 reset = 0;
           force clk = 0;
      #500 release clk;
      #0 reset = 1;
      #100 $finish;
      bit got_2clk, done;
      // if($fell(reset, @(posedge clk)))
       begin  : fall_reset
          begin : one
            got_2clk=1'b1;
            done=1'b1;
            -> eclk;
          end  : one
          begin : two
            #(period*2 +1);
            done=1'b1;
            ->eanalog;
          end : two
        join_none
        wait(done);
        got_2clk=1'b0;
        done=1'b0;
      end : fall_reset
    end  : b0
Sim result
ASSERT: Error: ASRT_0301 testbench.sv(40): Immediate assert condition “a_2clk” FAILED at time: 121ns, scope: top
  1. SVA Package: Dynamic and range delays and repeats https://rb.gy/a89jlh
  3. Papers:
Is your motivation to ensure reset is active long enough? If yes, consider below pseudo-code (not fully tested, will have corner case issues).
 always @ (posedge clk) begin
    if (reset) begin
      rst_cyc_count <= 0;
    else begin
      rst_cyc_count <= rst_cyc_count + 1;
  a_rst_cyc_chk : assert property (
    @ (posedge clk)
    ##1 $rose(reset) |-> (rst_cyc_count > 2) );
In reply to Srini @ CVCblr.com:
Srini, my co-author on many books, I like your sva solution. I should have thought of it. A minor comment, if reset stayed low all the time the assertion would not fail. The ‘s_eventually’ issue. The fork-join_none solution addresses that.
Ben systemverilog.us
Thank you very much, with this update it works flawlessly.
The concept is really brilliant - perfect example of thinking outside the box, I think I will make good use of it in the future.
Hi Srini,
I like your solution really much, it’s simple and elegant.
Unfortunately the motivation is not to ensure the reset length, but to make sure that a possible ongoing transfer finishes. Because of this I prefer Ben’s solution for the reason he mentioned.
FWIW, this concept was a derivation of of my modeling SVA with fork-join_none.
I strongly encourage you to read my paper
  • Understanding the SVA Engine,
    Verification Horizons - July 2020 | Verification Academy
    It will give more insights into how SVA works, and that will help you write better SVA code.
    BTW, that paper is just a model of SVA, it is NOT how vendors implement it, but still, it is of value particualrly if you want to write a concurrent assertion in a class (where SVA is illegal). If you have dynamic repeats and delays, see my package (link below).
  3. Papers:
