A grant must at some time have been preceded by a request
I have a simple spec “A grant must at some time have been preceded by a request”
If grant arrives and request never arrives before grant, the assertion fails. Need to look in the past for request, but would not know when request would have arrived.
$past only looks in the ‘past’ a fixed number of clocks. How do you make it look in the past forever?
Thanks much.
Ashok
In reply to a72:
You need to latch the occurrence of req. Thus,
    bit clk, req, grnt, req_occurred, reset_n;
    always @(posedge clk) begin
        if($sampled(req))  req_occurred <= 1'b1; // updated with the $sampled(
        if($sampled(grnt)) req_occurred <= 1'b0;
   ap_grant: assert property(@(posedge clk) $rose(grnt) |-> req_occurred);
  3. Papers:
Thanks, Ben. So, it seems one has to develop ‘satellite’ supporting code to augment the assertion. I understand.
Hi Ben,
I think below should work too? eliminating the need for helper code. let me know what you think.
sequence s_req;
rose(req) ##[1:] 1’b1; // endpoints at 0,1,2,… cycles after req
endsequence
grant : assert property (
@(posedge clk)
$rose(gnt) |-> s_req.triggered;
In reply to DVtrojan:
  • ##[*1:$] req; // is syntactically incorrect
  • You probably meant: ##[1:$] req;
  • You would need a first_match(##[1:$] req)
  • My reservation on this solution is that it is not efficient as it creates at every attempt multiple threads.
Ben
had a typo just fixed
sequence s_req;
rose(req) ##[1:] 1’b1; // endpoints at 1,2,… cycles after req
endsequence
  • rose(req) ##[1:] 1’b1; // after the 1st req you get an endpoint at every cycle thereafter, till infinity.
  • The 1st attempt with the rose gnt would be OK. However,
  • $rose(gnt) |-> s_req.triggered;
    with any 2nd, 3rd, …nth grant the assertion would would be immediately passed.
    This is because the sequence (rose(req) ##[1:] 1’b1) is causing and endpoint at every cycle after the 1st rose of req
For the triggered solution to work, use this sequence declaration
sequence s_req;
  @(posedge clk). // updated.
  first_match($rose(req) ##[1:$] gnt; // ##1 1'b1); // endpoint 1 cycle after gnt
endsequence
// the endpoint of the sequence must end when
// the $rose(gnt) occurs
// Note: This solution has many threads for each successful attempt
Read my paper Understanding the SVA Engine,
https://verificationacademy.com/verification-horizons/july-2020-volume-16-issue-2
Thanks Ben!
Glad you liked my reply.
BTW, I made a correction above.
Always verify your assertions, preferably with a simulator.
Ben
