Work around for generating particular code using generate block with dynamic variable in SVA for assert property
// length value will change dynamically, len is signal
// READ_DATA = 32;
// tag is some value.
for(genvar i = 0; i <= (length/(READ_DATA/8)); i++) begin
         property_a: assert property (P_TAG_CHECK(tag))
	         else $error("ERROR");
I am using this genvar approach, it is throwing error(Because of dynamic variable) any work around for that (or) any other approach for this scenario.
My intension is to generate assert properties based on the condition of length/(DATA_WIDTH/8).
In reply to Pavan Kumar Kollipara:
The easiest way to use dynamic variables in SVA is to use my package:
SVA Package: Dynamic and range delays and repeats SVA: Package for dynamic and range delays and repeats | Verification Academy
The file includes a testbench.
  3. Papers:
Hello Ben,
Thanks for your reply,
   // READ_DATA = 32;
  sequence STS_AND_TAG_CHECK(tag);
	@(posedge rd_rsp_clk) disable iff (rst_n !== 1)
	rdata_valid |-> ((rdata_tag == tag) && (wr_rsp_error == 0 || wr_rsp_error == 1));
  endsequence: STS_AND_TAG_CHECK
   // ******       DYNAMIC REPEAT q_s[*d1] **********
   // Application:  $rose(a)  |-> q_dynamic_repeat(q_s, d1) ##1 STS_AND_TAG_CHECK;
   sequence q_dynamic_repeat(count);
       int v=count;
       (1, v=count) ##0 first_match((1, v=v-1'b1) [*1:$] ##0 v<=0);
   endsequence
   A_STS_AND_TAG: assert property ($rose(cmd_valid) |-> q_dynamic_repeat(cmd_len/(READ_DATA/8)) ##0 STS_AND_TAG_CHECK(cmd_tag))
please let me know it is correct or not.
Show me the property (P_TAG_CHECK(tag))
Ben
Hello Ben,
This is the assertion I have written previously,
property P_TAG_CHECK(tag);
		rdata_valid ##0 ((rdata_tag == tag) && (rdata_error == 0 || rdata_error == 1));
endproperty: P_TAG_CHECK
// length(signal) is the signal changes with every command valid
// parameter READ_DATA = 32;
always @(posedge cmd_valid) begin
      if(cmd_type == 0 && cmd_last == 1) begin
Pavan.
I don’t understand your assertion.
So you want to dynamically start (or fire) a number of assertions based on a value of a variable. I generally have used the genvar in the generate construct. The following should work:
           for(int i = 0; i <= (length/(READ_DATA/8)); i++) begin
But I don’t understand why you need to create multiple identical assertions. Specifically,
assuming that at time t (length/(READ_DATA/8))== 3, this for loop create 3 identical assertions that are initated at @(posedge rd_rsp_clk) and last 1 cycle. The value of “tag” is identical for all 3, and “tag” does not depend on the iteration loop “i”. If you had something like P_TAG_CHECK(tag * i), then I can perhaps see some value to the multiple separate assertions. What you wrote could be simplified without the for loop.
My package deals with dynamic delays and repeats; you have none of that here.
  1. SVA Package: Dynamic and range delays and repeats https://rb.gy/a89jlh
  3. Papers:
Hello Ben,
Here length and tag value changes with the cmd_valid, for every cmd_valid those both tag and length values will change.
I have used previously by keeping only for loop, I am getting Below error
Error-[V2KGEUV] Unknown or bad value for genvar
/src/assertions/mim_bfm_assertions.sv, 659
  Instance/Generate block name: test_tb.tes_if.u_test_assert
  Elaboration time unknown or bad value encountered for generate for-statement
  condition expression.
  Please make sure it is elaboration time constant.
I still don’t understand why you need a loop. Typically, in assertions, you may want to use the generate statement to instantiate multiple assertions based on the the genvar variable. For example:
module arbiter;
//If I have to test a arbiter encoded arbiter with say, 4-inputs (request signals) and 4-outputs (grant signals),
//What assertions are required for verifying this arbiter?
	bit[15:0] req, grnt;
	bit clk;
	initial forever #5 clk=!clk;
  generate for (genvar i=0; i<=15; i++)
      property p_arbiter;
        bit[16:0] v;
         (req*==1'b1, v=0, v[i+1]=1'b1) ##0 req < v |->
          grnt[i]==1'b1 ##0 $onehot(grnt);
      endproperty : p_arbiter
      ap_arbiter: assert property(@(posedge clk) p_arbiter);
  endgenerate
In your model, I believe that you need to put the conditions to do the verification in the antecendent. Before getting into it, I am puzzled by the expression
Unless rdata_error is a vector and can have other values, the expr && (bit_a==0 || bit_a==1) is equivalent to expr.
             (rdata_error == 0 || rdata_error == 1));	// rdata_error is NOT a bit
  p_a: assert property(@(posedge cmd_valid)
          cmd_type == 0 && cmd_last == 1) |-> P_TAG_CHECK(tag))
Comments:
  1. Why are you using 2 clock systems: (posedge cmd_valid) and (posedge rd_rsp_clk).
    Remember that the variables are sampled in the Preponed Region. @(posedge cmd_valid) cmd_type is sampled just before the event (posedge cmd_valid).
  2. You can use the generate endgenerate, this is expanded at elaboration and not during simulation.
  3. rethink your model. I don’t believe that you fully understand the requirements because you are having a very hard time expressing them in a verification language.
  4. take a look at my paper [i]Understanding the SVA Engine,*, you may want to use that approach if that is simpler for you.
    Verification Horizons - July 2020 | Verification Academy
  3. Papers:
Thanks Ben for your detailed explanation, I have understood the problem and will modify code according to the perfect scenario
Ben – take a look at my paper Understanding the SVA Engine, you may want to use that approach if that is simpler for you.
I will go thorough this paper once.
Pavan.
