Within ' disable iff ( ! reset ) , is the reset synchronous OR asynchronous?
Typically we can disable a property expression via :: ’ disable iff ’
 property  ab ;
  @( posedge clk ) disable iff ( ! reset )  $rose( a ) |=> b ;
Variables ’ a ’ N ’ b ’ are Sampled ( in preponed region ) and the expression is evaluated ( in Observed region ) ONLY during posedge of clk .
**Is the active low variable ’ reset ’ evaluated ONLY during posedge of clk ( i.e evaluated synchronously ) OR
if the reset were to go low during negedge of clk ( i.e when the property isn’t evaluated ) the assertion would still be disabled / discarded ?**
In reply to hisingh:
The disable iff ( ! reset ) is asynchronous.
From my SVA book:
To provide a synchronous abort, three not identical options with specific implications can be used: 1) With the sync_accept_on (see 3.9.14); for example:
ap_sync: assert property(@ (posedge clk)
   sync_accept_on (!rst_n) // If rst_n==0 then assertion is vacuously true
     a |-> ##3 b);
  1. With a sampled valued function (see 4.2.1.2); for example :
ap_dis_sync: assert property(@ (posedge clk) // If synchronous fell(rst_n)
   disable iff ($fell(!rst_n, @(posedge clk))) // then assertion is cancelled
     a |-> ##3 b);
/* Note that this approach is not always ideal, particularly for designs where the reset signal is active low and is generated from a power supply circuit and is maintained in the zero state until the supply voltage is stable (e.g., at 5V). In this case, there is no $fell(!rst_n); $rose(!rst_n) would work, but any future resets would be problematic since they would not emulate RTL logic.*/
  1. With the triggered of a sequence; for example:
sequence qSoftReset2; @ (posedge clk) $rose(soft_hardware_reset_command) ##1 ack;
endsequence : qSoftReset2
apTest: assert property (
    @ (posedge clk) disable iff (qSoftReset2.triggered)
     a |=> b);
  3. Papers:
Ben is there a way to check the aysnchronous part via reports ( $display() ) .
For example ::
 //  Within  procedural  blocks
   always @( negedge rst_n  ,  posedge clk )
       if ( ! rst_n )  begin
        $display($time,,,"...") ; //  Can  report  N  check  that  reset  was  asynchronous
         //  Drive  initial  values  to  signals
          //  Non - Reset Logic  here
Similarly can we have a report specifically when the reset is asserted in the concurrent assertion ?
Instead of the $display, use the immediate cover with an action block.
Ben I am not sure if I get your comment .
Do you mean this way ::
        assert ( ! rsn ) $display($time,,,"...") ;  //  Immediate  assertion .
I was looking for a way in concurrent assertion written outside procedural block. Like in the example at the top .
        c_reset: cover(1) $display($time,,,"...") ;  //  Immediate  assertion .
        // Since you know that rst_n==0, you can use "1"
        // but cover or assert of rst_n is OK too
   // concurrent assertion statement; it needs a clocking event
   cp: cover property(@(negedge rst_n) 1); //  negedge rst_n occurred
Ben
What seems to work for me as well is this:
ap_dis_sync: assert property(@(posedge clk)
   disable iff ($sampled(rsti_i)) // sample `rst_i` at the beginning of the simulation tick
@Ben: Do you see anything wrong with that?
In reply to No:
That’s OK too.
I used that form before.
