In reply to hisingh:
The disable iff ( ! reset ) is asynchronous.
From my SVA book:
To provide a synchronous abort, three not identical options with specific implications can be used: 1) With the sync_accept_on (see 3.9.14); for example:
ap_sync: assert property(@ (posedge clk)
sync_accept_on (!rst_n) // If rst_n==0 then assertion is vacuously true
a |-> ##3 b);
- With a sampled valued function (see 4.2.1.2); for example :
ap_dis_sync: assert property(@ (posedge clk) // If synchronous fell(rst_n)
disable iff ($fell(!rst_n, @(posedge clk))) // then assertion is cancelled
a |-> ##3 b);
/* Note that this approach is not always ideal, particularly for designs where the reset signal is active low and is generated from a power supply circuit and is maintained in the zero state until the supply voltage is stable (e.g., at 5V). In this case, there is no $fell(!rst_n); $rose(!rst_n) would work, but any future resets would be problematic since they would not emulate RTL logic.*/
- With the triggered of a sequence; for example:
sequence qSoftReset2; @ (posedge clk) $rose(soft_hardware_reset_command) ##1 ack;
endsequence : qSoftReset2
apTest: assert property (
@ (posedge clk) disable iff (qSoftReset2.triggered)
a |=> b);
Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb - Papers:
Verification Horizons - July 2020 | Verification Academy - SVA Alternative for Complex Assertions
