How to use the arguments of two different sequences for comparing in a third sequence using Assertions?
I coded assertion like this but the simulator is showing this error
** Error: …/ref/i2c_assertions.sv(82): Illegal SVA expression in Verilog expression.
Can anyone point out what’s the mistake?
//START condition
//Detects the time where SCL went LOW
sequence scl_fall(Tscl_fall);
($fell(I2C_INTERFACE.scl),Tscl_fall=$time);
endsequence
//Detects where the time where SDA went LOW
sequence sda_fall(Tsda_fall);
($fell(I2C_INTERFACE.sda),Tsda_fall=$time);
endsequence
//Checking for START condition
sequence s1;
time t1,t2;
(((scl_fall(t1))>(sda_fall(t2))),$display("START condition dtected at %0t",sda_fall(t2)));
endsequence
property p1;
@(negedge I2C_INTERFACE.scl) s1 ;
I explain the issue you have in my SVA Handbook; basically, typed formal arguments declared as local variables can be exported to the calling unit, such as the property or sequence, if they are prefixed with the reserved word local and are declared of direction inout or output. Variables declared in the assertion variable declaration region (i.e., those not in the port list) cannot be exported. Here is a link to my book that explains the rules in handling the exportation of local variable
Below is the sample code and simple testbench for it.
//1.  Data transfer from the external interface into the driver.
//2.  Data transfer from the driver to the memory through another interface.
//3.  Verification that data stored into the memory at that address location is identical to what was originally transferred from the originator of the data
module var_example;
    bit clk, ext1_req, ext1_ack, ext1_rd_wrf;
    bit ext2_req, ext2_ack, ext2_rd_wrf;
    byte ext1_data, ext2_data, drv_data;
    byte mem[0:1024];
    bit[0:9] ext1_addr, ext2_addr;
    initial forever #10 clk=!clk;
    default clocking cb_clk @ (posedge clk);
    endclocking
    sequence q_ext1_to_driver(local output byte v_data,
        local output bit[0:9] v_addr);
        first_match (($rose(ext1_req) && !ext1_rd_wrf, v_data=ext1_data,
        v_addr=ext1_addr)  ##[1:3] ext1_ack);
    endsequence : q_ext1_to_driver
    sequence q_ext2_to_mem(local input byte v_data, local input bit[0:9] v_addr);
        ext2_req ##0 !ext2_rd_wrf ##0 ext2_data==v_data ##0 ext2_addr==v_addr ##
        1 ext2_ack ##[1:3] mem[v_addr]==v_data;
    endsequence
    property p_ext1_to_mem;
        byte v_data;
        bit[0:9] v_addr;
        q_ext1_to_driver(v_data, v_addr) |->
        ##[1:3] q_ext2_to_mem(v_data, v_addr);
    endproperty : p_ext1_to_mem
    ap_ext1_to_mem: assert property(p_ext1_to_mem);
    always begin
        if(!randomize(ext1_data, ext1_addr))  $display("randomization failure");
        @ (posedge clk);
        ext1_req <= 1'b1;
        ext1_rd_wrf <= 1'b0;
        mem[ext1_addr] <= ext1_data; // preload of data for test only
        @ (posedge clk);
        ext1_req <= 1'b0;
        ext1_rd_wrf <= 1'b1;
        ext1_ack <= 1'b1;
        @ (posedge clk);
        ext2_req <= 1'b1;
        ext2_rd_wrf <= 1'b0;
        ext2_data <= ext1_data;
        ext2_addr <= ext1_addr;
        ext1_ack <= 1'b0;
        @ (posedge clk);
        ext2_req <= 1'b0;
        ext2_rd_wrf <= 1'b1;
        ext2_ack <= 1'b1;
        @ (posedge clk);
        ext2_ack <= 1'b0;
        repeat (5) @ (posedge clk);
endmodule : var_example
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
Thanks for the reply Ben.Actually I am trying to write assertions for I2C protocol where I need to check the following scenarios.
1.START condition
When SCL is HIGH and before it goes LOW, SDA should go LOW.(Here SDA and SCL start from being HIGH initially)
2.The START condition is followed by checking of config class variable being 1 at posedge of SCL.
How to generate actual delays instead of Cycle delays?
I wrote a code like this will it work?If not please suggest me a better method sir.
 sequence s1;
	@(negedge I2C_INTERFACE.sda) (I2C_INTERFACE.scl==1);
endsequence
task posedge_delay();
	@(posedge I2C_INTERFACE.scl);
property p1;
	@(negedge I2C_INTERFACE.sda) s1;
property p5;
	@ (posedge I2C_INTERFACE.scl)	s1|->(1'b1,posedge_delay)|->(slave_addr_tran==1'b1);
In reply to rajan passionate:
Consider using the within sequence operator. The sequence containment within specifies a sequence occurring within another sequence.
Note: (seq1 within seq2) is equivalent to:
((1[*0:] ##1 seq1 ##1 1[*0:]) intersect seq2 )
You also seem to overuse the sequence declaration, and I see no use for your task.
I don’t know if this assertion will work for you, but I suggest something like.
// When SCL is HIGH and before it goes LOW,
//   SDA should go LOW.(Here SDA and SCL start from being HIGH initially)
ap_scl: assert property(
  @ (posedge some_clock) $rose(scl)|-> !sda[->1] within $fell(scl)[->1]);
// @ (posedge some_clock) $rose(scl)|-> !sda[->1] within ($fell(scl) && sda)[->1]);
// A pootential other option.
// As far as "(1'b1,posedge_delay)|->(slave_addr_tran==1'b1)"
// I have no idea as to what you are talking about.
// If there is a relationship between $fell(sda) and slave_addr_tran,
// write another assertion
1.Here my clock itself is scl.So,I cant check the START condition if I use @(posedge scl) as my clocking event.So, I used @(negedge sda).
2.After START was detected,at the next immediate posedge of SCL,checking of cfg.slave_addr_tran ==1’b1 should be done.So, I thought of using a task which will produce delay of one posedge of scl.
Show the code. Did you compile it too?
Ben
BTW, firing a task from a sequence_match_item just fires it, like a function call. There is no time consumption in the assertion.
It is discouraged to use tasks; I haven’t chhecked, but I believe it might be illegal. If legal, it does nothing for the assertion (no time consumption processed by the assertion as a result of the task call). You can use functions that consume no time.
Ben SystemVerilog.us
//`include "i2c_config.sv"
import CONFIG::*;
module i2c_assertions();
time Tsda_rise,Tscl_rise;
time Tscl_fall,Tsda_fall;
logic scl;
bit slave_addr_tran;
bit mem_addr_tran;
bit data_tran_WR;
bit data_tran_RD;
i2c_if I2C_INTERFACE(.scl(scl));
initial
i2c_config cfg;
//cfg = new();
always @(posedge I2C_INTERFACE.scl)
	slave_addr_tran   =   cfg.slave_addr_tran;
	mem_addr_tran     =   cfg.mem_addr_tran;
	data_tran_WR  =   cfg.data_tran_WR;
	data_tran_RD  =   cfg.data_tran_RD;
//Config class
//*******************************************************PROPERTIES and SEQUENCES*****************************************************//
//typedef class i2c_config;// cfg;
//cfg = new();
initial
cfg = new();
//START condition
//Detects START condition
sequence s1;
endsequence
property p1;
//Detects STOP condition
sequence s2;
	@(posedge I2C_INTERFACE.sda) (I2C_INTERFACE.scl==1);
endsequence
property p2;
@(negedge I2C_INTERFACE.sda) s2;
//BUS IDLE
property p4;
@(I2C_INTERFACE.scl) s2|=>(I2C_INTERFACE.sda && I2C_INTERFACE.scl)|=>s1;
//SLAVE ADDRESS TRANSFER & ACK
//SLAVE ADDRESS trasnfer starts
property p5;
//SLAVE ADDRESS transfer ends
property p6;
@(posedge I2C_INTERFACE.scl) s1|=> ##8 (slave_addr_tran==1'b0);
//SLAVE ADDRESS ACK
property p7;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe));
//MEMORY ADDRESS TRANSFER & ACK
//MEMORY ADDRESS transfer starts
property p8;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9 !(I2C_INTERFACE.sda_oe)|=>(mem_addr_tran==1'b1);
//MEMORY ADDRESS transfer ends
property p9;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=> ##8 (mem_addr_tran==1'b0);
//MEMORY ADDRESS ACK
property p10;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe));
//DATA TRANSFER & ACK (WRITE operation)
//DATA TRANSFER starts
property p11;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe))|=>(data_tran_WR==1'b1);
//DATA TRANSFER ends
property p12;
@(posedge I2C_INTERFACE.scl) s1|=> (cfg.slave_addr_tran_WR==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe))|=>##8 (cfg.data_tran_WR==1'b0);
//DATA TRANSFER ACK (by Slave)
property p13;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe))|->##9 (!(I2C_INTERFACE.sda_oe));
//DATA TRANSFER & ACK (READ operation)
property p14;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe))|=>(data_tran_RD==1'b1);
property p15;
@(posedge I2C_INTERFACE.scl) s1|=> (cfg.slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe))|=>##8 (cfg.data_tran_RD==1'b0);
//DATA TRANSFER ACK (by Master)
property p16;
@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|->##9(!(I2C_INTERFACE.sda_oe))|=>##9 (!(I2C_INTERFACE.sda_oe))|->##9 !(I2C_INTERFACE.sda);
//RepStart condition
//When slave didn't respond during slave address transfer
property p17;
	@(posedge I2C_INTERFACE.scl) s1|=> (slave_addr_tran==1'b1)|=>##9 (I2C_INTERFACE.sda_oe);
//When NACK sent during memory address transfer
property p18;
@(posedge I2C_INTERFACE.scl) s1|=> (mem_addr_tran==1'b1)|=>##9 (I2C_INTERFACE.sda_oe);
//When NACK sent during data transfer
//WRITE to slave
property p19;
@(posedge I2C_INTERFACE.scl) s1|=> (data_tran_WR==1'b1)|=>##9 (I2C_INTERFACE.sda_oe);
//READ from slave
property p20;
@(posedge I2C_INTERFACE.scl) s1|=> (data_tran_RD==1'b1)|=>##9 (I2C_INTERFACE.sda);
//WRITE operation DETECT
property p21;
@(posedge I2C_INTERFACE.scl) s1|=> ##8(!(I2C_INTERFACE.sda));
//READ operation detect
property p22;
@(posedge I2C_INTERFACE.scl) s1|=> ##8 I2C_INTERFACE.sda;
property p23;
//NACK sent by slave when master sends memory address
property p24;
//NACK sent by slave after sending data to slave
property p25;
//NACK sent by master after recieving data from slave
property p26;
//Illegal Format (START followed by STOP in the next cycle)
property p27;
@(posedge I2C_INTERFACE.scl) s1 |=> s2;
/////////////*****************************************************************ASSERTIONS*******************************************************************/////////////
START      :  assert property (p1) $display (" START condition detected at %0t ",$time); else $display("START NOT DETECTED")  ;
STOP       :  assert property (p2) $display (" STOP condition detected at %0t ",$time);
//VALID_DATA :  assert property (p3) $display (" INVALID SDA TRANSITION ");          else    $display("Assertion Failed : INVALID DATA");
//BUS_IDLE   :  assert property (p4) $display (" I2C bus went to IDLE state ");
SLAVE_ADDR_TRANSFER_START      :     assert property (p5)  $display (" SLAVE ADDRESS transfer started ");
SLAVE_ADDR_TRANSFER_END        :     assert property (p6)  $display (" SLAVE ADDRESS transfer ended ");
SLAVE_ADDR_ACK                 :     assert property (p7)  $display (" SLAVE generated ACK ");
NO_RESPONSE_FROM_SLAVE         :     assert property (p23) $display (" SLAVE not responded for the slave address sent");
MEM_ADDR_TRANSFER_START        :     assert property (p8)  $display (" MEMORY ADDRESS transfer started ");
MEM_ADDR_TRANSFER_END          :     assert property (p9)  $display (" MEMORY ADDRESS transfer ended ");
WRITE_TO_SLAVE_DETECT          :     assert property (p21) $display (" MASTER WRITES TO SLAVE ");
READ_FROM_SLAVE_DETECT         :     assert property (p22) $display (" MASTER READS FROM SLAVE ");
MEM_ADDR_ACK                   :     assert property (p10) $display (" SLAVE generated ACK after memory address has been sent by master ");
MEM_ADDR_NACK                  :     assert property (p24) $display (" SLAVE generated NACK after memory address has been sent by master ");
WRITE_DATA_TRANSFER_START      :     assert property (p11) $display (" DATA TRANSFER STARTED ");
//WRITE_DATA_TRANSFER_END        :     assert property (p12) $display (" DATA TRANSFER ENDED ");
DATA_ACK_BY_SLAVE              :     assert property (p13) $display (" SLAVE generated ACK ");
DATA_NACK_BY_SLAVE             :     assert property (p25) $display (" SLAVE generated NACK after data has been sent by master ");
READ_DATA_TRANSFER_START       :     assert property (p14) $display (" DATA TRANSFER STARTED ");
//READ_DATA_TRANSFER_END         :     assert property (p15) $display (" DATA TRANSFER ENDED ");
DATA_ACK_BY_MASTER             :     assert property (p16) $display (" MASTER generated ACK after data has been sent by SLAVE  ");
DATA_NACK_BY_MASTER            :     assert property (p26) $display (" MASTER generated NACK after data has been sent by SLAVE ");
REP_START_1                    :     assert property (p17) $display (" RPEATED START DETECTED (No response to the SLAVE ADDRESS sent) ");
REP_START_2                    :     assert property (p18) $display (" REPEATED START DETECTED (SLAVE generated NACK after the MEMORY ADDRESS  has been sent by the MASTER) ");
REP_START_3                    :     assert property (p19) $display (" REPEATED START DETECTED (SLAVE generated NACK after the DATA  has been sent by the  MASTER) ");
REP_START_4                    :     assert property (p20) $display (" REPEATED START DETECTED (MASTER generated NACK after the DATA has been sent by the slave) ");
ILLEGAL_FORMAT                 :     assert property (p27) $display (" ILLGEAL FORMAT:START followed by STOP in the next cycle ");
Yes Ben, it is compiling and simulating too.But as the DUT has some bug all are vacuosly passed!!
I don’t have the time to debug it for you, as it is too specific.
Some general comments though about your style:
  • You use too many sequence declarations
  • Don’t fire tasks from sequence_match_items; they consume no time in the assertion,
  • For sequence_match_items, you can use functions.
  • If you are using the properties once, and do not use local variables avoid using property declarations; they make the code harder to follow.
Ben http://SystemVerilog.us
But ben, how to use non-clocked delays for checking the sequences? (Delays less than one clock cycle).
SVA is event-based with variables samples in the Preponed region of the event.
Events are usually clocking event, but could be user-defined events (declared with the event type).
Assertions are really intended to verify and cover properties based on the relationships of variables (e.g, req |=> ack)
For delays, you could use supporting logic yo create events.
Write multiple small assertions instead of 1 compex one.
Ben
Ok Ben.How can I do like that in my case?
It is quite complicated here.Because,
START condition has to be checked first when scl is HIGH.Then scl should go LOW and after some time it should go HIGH and at this posedge of SCL I need to sample a variable.
The problem occurs due clocking event.Because for START condition ,the clocking event is negedge of sda and for sampling the variable(cfg.slave_addr_tran) the clocking event is posedge scl.
Please suggest some solution.
General comments:
  • SVA can use multiclocks,
    @(posedge clk1) a |-> @(posedge clk2) b
  • Solve your particular verification with plain SystemVerilog code
    e.g.,
always   @(posedge clk)  begin
On this forum, I generally provide guidance and quick help. However, for detailed complex problems, I really do not have the time, and besides, it is not my responsibility anyway.
Best wishes.
Ben
