How to use the arguments of two different sequences for comparing in a third sequence using Assertions?
1.Here my clock itself is scl.So,I cant check the START condition if I use @(posedge scl) as my clocking event.So, I used @(negedge sda).
2.After START was detected,at the next immediate posedge of SCL,checking of cfg.slave_addr_tran ==1’b1 should be done.So, I thought of using a task which will produce delay of one posedge of scl.
