How to use the arguments of two different sequences for comparing in a third sequence using Assertions?
In reply to rajan passionate:
Consider using the within sequence operator. The sequence containment within specifies a sequence occurring within another sequence.
Note: (seq1 within seq2) is equivalent to:
((1[*0:] ##1 seq1 ##1 1[*0:]) intersect seq2 )
You also seem to overuse the sequence declaration, and I see no use for your task.
I don’t know if this assertion will work for you, but I suggest something like.
// When SCL is HIGH and before it goes LOW,
//   SDA should go LOW.(Here SDA and SCL start from being HIGH initially)
ap_scl: assert property(
  @ (posedge some_clock) $rose(scl)|-> !sda[->1] within $fell(scl)[->1]);
// @ (posedge some_clock) $rose(scl)|-> !sda[->1] within ($fell(scl) && sda)[->1]);
// A pootential other option.
// As far as "(1'b1,posedge_delay)|->(slave_addr_tran==1'b1)"
// I have no idea as to what you are talking about.
// If there is a relationship between $fell(sda) and slave_addr_tran,
// write another assertion
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
