I am fairly new to SystemVerilog and trying to learn SV interface and modport construct by connecting a Verilog module with ports to a particular modport of an interface. I get “Cross module reference resolution error, illegal use of modport”.
Can anyone please hep me understand this basic coding practice?
Hi Nikhil. Modports are used to connect two modules together that employ interfaces in their port list, and to specify the port direction. In your case, module add does not use an interface. The module instantiation should be:
Please show your code and the errors you are getting. We can not make recommendations without knowing these.
Modports are used as encapsulation of signals. You should only reference the individual signals from where the modport is used as a port. If your DUT has a pin level interface, then you should connect only the pins. If your DUT uses a modport in place of pins, then you should connect the modport.
Hi all, I am trying to access signals through modport in my sub-module(DUT) and for that, I am using (interface.modport) in a module and in dut_wrapper which is a wrapper I am passing (interface_instance) in wrapper module. The code is passing but I have doubt whether dut(sub-module ) is using interface signal or modport signal.
Here My intention is to use modport for signal driving.
Please clear my doubt.
Thanks in advance
The used code is shared below -:
module Testbench;
parameter tb_data_size=16;
parameter tb_array_depth=10;
bit clk;
int clk_count;
// clock generation
assign dut_wrapper.clk = clk;
always #1 clk = ~ clk;
// Simulation temination based on clock count
always @(posedge clk) begin clk_count++; end
always @(negedge clk) begin if(clk_count == 20) $finish; end
// instatiation of different rtl
//intf#(tb_data_size) d_if(clk); // interface instance
// stimulation genration and drive
reg [tb_data_size-1:0]inp1[tb_array_depth];
// reg [tb_data_size-1:0]inp2;
wire[tb_data_size:0]out1[tb_array_depth];
assign dut_wrapper.d_if.inp1 = inp1;
//assign dut_wrapper.d_if.inp2 = inp2;
assign out1 = dut_wrapper.d_if.out1 ;
initial
// initialization
clk_count = 0;
foreach (inp1[i]) inp1[i] = 0;
// inp2 = 0;
#2;
// stimulas
//repeat(10)
for(int i=0; i<= 10; i++)
#2
//inp1 = $urandom_range(15,40);
foreach (inp1[i])
inp1[i] = $urandom;
// inp2 = $urandom_range(50,60);
reg [tb_data_size:0]r_out1[tb_array_depth];
int add_er;
foreach (inp1[i])
r_out1[i] = inp1[i] ;
foreach (out1[i])
if(r_out1[i] != out1[i]) add_er ++;
// display statement
always @(posedge dut_wrapper.d_if.clk)
foreach (inp1[i])
$display(":*TB:input1=%0d output1=%0d",inp1[i],out1[i]);
//final
final
if(add_er != 0)
$display("\n Test Failed:\n dut checking max arry size not working correct");
$display("\n Test Passed:\n dut checking max array size working correct");
interface intf#(data_size,array_depth)(input bit clk);
logic [data_size-1:0]inp1[array_depth];
// logic [data_size-1:0]inp2[array_depth];
logic [data_size:0]out1[array_depth];
modport mp(input clk,input inp1,output out1);
endinterface
module dut_wrapper;
parameter dut_data_size=16;
parameter dut_array_depth=10;
reg clk;
reg [dut_data_size-1:0]inp1[dut_array_depth];
wire[dut_data_size:0]out1[dut_array_depth];
// rtl and other instantiation
intf#(dut_data_size,dut_array_depth) d_if(clk);
dut#(dut_data_size,dut_array_depth) dut1(d_if);
//initial foreach (inp1[i]) $monitor($time,,":DUT_wraper: input1=%0d output=%0d",inp1[i],out1[i]);
always @(posedge clk) foreach (inp1[i]) $display($time,,":DUT_wraper: input1=%0d output=%0d",d_if.inp1[i],d_if.out1[i]);
module dut#(data_size,array_depth)(intf.mp d1);
//module dut#(data_size,array_depth)(clk,inp1,out1);
//parameter size = 8
//input clk;
//input [data_size-1:0] inp1[array_depth];
//output [data_size:0]out1[array_depth];
reg [data_size:0] r_out1[array_depth];
assign d1.out1 = r_out1;
always @(posedge d1.clk)
foreach (d1.inp1[i])
r_out1[i] = d1.inp1[i];
$display($time,,":DUT:input1=%0d output=%0d",d1.inp1[i],d1.out1[i]);
