Checking a clock using SVA
If there is a clock with frequency 1MHz and 30% duty cycle,how to check this clock if it has any glitches or not using System Verilog Assertions (SVA)?
In reply to perumallatarun:
The following solution works, and includes a testbench. That testbench follows the style demonstrated in my 4th edition SVA book regarding verifying assertions.
module m;
	bit clk=1, a;
	bit[0:1] t;
	initial forever begin
	   #298 if (!randomize(t)  with
           { t dist {1'b1:=1, 1'b0:=10};
       if(t) begin
          clk=!clk;
	      #1ns clk=!clk;
	      #1ns clk=!clk;
	   else #2ns clk=!clk;
	   #398  if (!randomize(t)  with
       if(t) begin
          clk=!clk;
	      #1ns clk=!clk;
	      #1ns;
	   else #2ns;
	   #300  clk=!clk;
	property p_clk_hi;
	  time v;
	  @(posedge clk) (1, v=$time) |-> @(negedge clk) ($time-v)==300ns;
	ap_clk_hi: assert property(p_clk_hi);
	property p_clk_lo;
	  time v;
	  @(negedge clk) (1, v=$time) |-> @(posedge clk) ($time-v)==700ns;
    ap_clk_lo: assert property(p_clk_lo);
  • SystemVerilog Assertions Handbook 4th Edition, 2016 ISBN 978-1518681448
Hi Ben,
Don’t you think it is better to use realtime instead of time datatype?
I feel that realtime allows one to reuse of assertions for gate-level simulations.
In reply to chitlesh:
Hi Ben,
Yes, realtime is better.
	property p_clk_hi;
	  realtime v;
	  @(posedge clk) (1, v=$realtime) |-> @(negedge clk) ($realtime-v)==300ns;
	property p_clk_lo;
	  realtime v;
	  @(negedge clk) (1, v=$time) |-> @(posedge clk) ($realtime-v)==700ns;
Hi Ben,
Is there any chance to write SVA for clock to check the frequency “inside an interface”.
Here we cannot use $real_time in interface, How to overcome this problem?.
Srikanth.
In reply to srikanth_manukonda:
What is so special about an interface that make you think you can’t use $realtime?
Be careful using equality with real numbers. See Comparing Floating Point Numbers, 2012 Edition | Random ASCII – tech blog of Bruce Dawson
I am facing compilation errors while using $real_time inside interface.
Error : cannot use real type in dynamic world
-Srikanth
Please show some code and the exact error message. That error message seems strange.
Error : cannot use real type in dynamic world -Srikanth
As Dave pointed out, there are no restrictions on using the “$realtime” in interfaces.
BTW, $realtime is spelled without the “_”; you have $real_time, which is in error.
Maybe that is your issue.
Hi Ben/Dave,
Do you guys personally think it’s better idea to check clock using property assertion ? I think the assertion will always be active through out the simulation. That will affect performance of the simulation time?
Just curious to know your views on same.
Digesh
In reply to Digesh:
  1. A concurrent assertion can be expressed with always and logic statements; thus, I don’t believe it would consume more simulation time than verification logic.
  2. As far as assertions always being active throughout the simulation, one can tailor the ON/OFF time of that verification logic (e.g., assertions or plain logic) via various techniques:
  • 3. $asserton, $assertoff
    4. initial statement with a defined number of repeats if needed
    5. process kill, fork/join, etc.
How can the same problem be handled using SVA but verifying with a formal checker tool and not in simulations?
Kanthi
