IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, November 8th at 3:00 AM US/Pacific.
The problem is in my vector both the Min and Max are variable length.
like,
data[(i8)+7 : (i8)] as i varies the ranges varies from 7:0, 15:8 etc. does the above statement behaves the similar way.
I just copied a part of my code and simiplified. My requirement is i have a 256 bit width data bus. I need to read and write to the sparse memory (assosiative array of bytes) based on some conditions like,
number of bytes to read from memory, mask bits etc. i took the data bus as bit [255:0] DATA.
Tried the below code for variable length part select.
reg [143:0] file_data_re0;
reg [143:0] file_data_im0;
bit [11:0] data_re0;
bit [11:0] data_im0;
for(i=0; i<=11;i++) begin
file_data_re0[((i+1)*12)-1 +: i*12] = data_re0;
file_data_im0[((i+1)*12)-1 +: i*12] = data_im0;
getting the following error
Error-[NCE] Non-constant expression
The following expression should be a constant.
Expression: (this.i * 12)
“…/verification/mss_uvm_tb/uvcs/brs_uvc/src/agents/rem_brs_agent/src/rem_brs_monitor.sv”,
113
Source info: file_data_re0[((i+1)12)-1 +: i12] = data_re0;
‘this’ is not an elaboration-time constant. To correct the error you may
convert this const variable to a parameter or a localparam.
