Why base class can't be assigned to derived class?
Why base class can’t be assigned to derived class?
class A;
  bit var1;
class B extends A;
  //No Variables defined
  A a =new();
  B b =new();
  initial
    b = a; // Compilation error
In reply to SMS:
class A; // Base class
  bit var1;
class B extends A;
  bit b1;
  A a =new();  // pointer to base
  B b =new(); // pointer to B, with access to a vars
          // if it were legal, then b points to the base class A
    b.b1=1'b1; // There would be no "b1" since the pointer b has no access to
               // the variables in class b (b pointer is to the base class)
Ben SystemVerilog.us
Thanks Ben,
My Query relates to the inheritance concept of OOPs.
If no extra properties defined in derived class, why compiler still complains about legal assignment.
class A;
  bit var1;
class B extends A;
  A a =new();
  B b =new();
  initial
–SMS
In reply to SMS:
Because assignment type compatibility rules are based on name of the type alone, not on the contents of the type. That keeps the rules simple and manageable. It’s no different if you had:
class A;
  bit var1;
class B;
  bit var1;
  A a =new();
  B b =new();
  initial
Thanks Dave.
When derived class assigned to base class, hope same rule applicable, then why tool not issuing any error.
class A;
  bit var1;
class B;
  bit var1;
  A a =new();
  B b =new();
  initial
    a = b; // No Compilation error
In reply to SMS:
Maybe that was a bit too simple. The key point you don’t look at the contents of a class type definition for compatibility.
