I am writing complete uvm testbench for fsm. My sequence isnt driving at all. I have completely checked my testbench and still not able to find whats wrong. Could you please help me out if I send you my code?
In reply to samy:
//Sequence item class
class seq_item extends uvm_sequence_item;
//Randomizing the transaction fields
rand bit in;
bit out;
bit [1:0] state;
//Object and utility macros
`uvm_object_utils_begin(seq_item)
`uvm_field_int(in,UVM_ALL_ON)
`uvm_field_int(out,UVM_ALL_ON)
`uvm_field_int(state,UVM_ALL_ON)
`uvm_object_utils_end
//Constructor
function new(string name="seq_item");
super.new(name);
//Sequence class
class seq extends uvm_sequence#(seq_item);
//Utility macro
`uvm_object_utils(seq)
//constructor
function new(string name="seq");
super.new(name);
//Body task
virtual task body();
repeat(40)
`uvm_create(req);
req.randomize();
`uvm_send(req);
//Sequencer class
class sequencer extends uvm_sequencer#(seq_item);
//Utility macro
`uvm_component_utils(sequencer)
//Constructor
function new(string name="sequencer",uvm_component parent);
super.new(name,parent);
//Driver class
class driver extends uvm_driver#(seq_item);
virtual intf vif; //Virtual Interface handle
//Utility Macro
`uvm_component_utils(driver)
//Constructor
function new(string name="driver",uvm_component parent);
//Build phase
super.build_phase(phase);
if(uvm_config_db#(virtual intf)::get(this,"","vif",vif))
`uvm_info("VIF",$sformatf("virtual interface handle has been set for:",get_full_name(),".vif"),UVM_LOW);
//Run phase
reset;
forever
drive();
seq_item_port.item_done();
task reset;
wait(vif.rst);
`uvm_info("INITIATION",$sformatf("Initialization has started"),UVM_LOW);
vif.in=0;
wait(!vif.rst);
`uvm_info("DONE",$sformatf("Intialization is done"),UVM_LOW);
//Drive task
task drive();
@(posedge vif.clk);
vif.in<=req.in;
req.state<=vif.state;
req.out<=vif.out;
`uvm_info("DRIVER",$sformatf("Input=%d\tState=%2b\tOutput=%d",vif.in,req.state,req.out),UVM_LOW);
$display($time,"input=%d",vif.in,"State=%2b",vif.state,"Output=%d",vif.out);
//Monitor class
class monitor extends uvm_monitor;
virtual intf vif;
uvm_analysis_port #(seq_item) pkt_obtained_port;
//Handle to store transaction information
seq_item trans;
//Utility Macro
`uvm_component_utils(monitor);
//Constructor
function new(string name="monitor",uvm_component parent);
trans=new;
pkt_obtained_port=new("pkt_obtained_port",this);
//Build phase
//Run phase
forever
@(negedge vif.clk);
trans.in=vif.in;
trans.state=vif.state;
trans.out=vif.out;
`uvm_info("MONITOR",$sformatf("Input=%d\tState=%2b\tOutput=%d",trans.in,trans.state,trans.out),UVM_LOW);
pkt_obtained_port.write(trans);
In reply to Muthamizh:
//Scoreboard class
class scoreboard extends uvm_scoreboard;
//Utility macro
`uvm_component_utils(scoreboard)
uvm_analysis_imp #(seq_item,scoreboard) pkt_obtained_export;
seq_item trans;
//Constructor
function new(string name="scoreboard",uvm_component parent);
//Build phase
pkt_obtained_export=new("pkt_obtained_export",this);
//Write function
virtual function void write(seq_item pkt);
$display("Packets received");
pkt.print();
//Agent class
class agent extends uvm_agent;
sequencer seqcr;
driver dri;
monitor moni;
//Utility macro
`uvm_component_utils(agent)
//Constructor
//Build phase
if(get_is_active()==UVM_ACTIVE)
dri=driver::type_id::create("dri",this);
seqcr=sequencer::type_id::create("seqcr",this);
moni=monitor::type_id::create("moni",this);
//Connect phase
super.connect_phase(phase);
dri.seq_item_port.connect(seqcr.seq_item_export);
//Environment class
class environment extends uvm_env;
agent agnt;
scoreboard sb;
//Utility Macro
`uvm_component_utils(environment)
//Constructor
function new(string name="environment",uvm_component parent);
//Build phase
agnt=agent::type_id::create("agnt",this);
sb=scoreboard::type_id::create("sb",this);
//Connect phase
agnt.moni.pkt_obtained_port.connect(sb.pkt_obtained_export);
//Test class
class test extends uvm_test;
//Utility Macro
`uvm_component_utils(test)
environment env;
seq seq1;
//Constructor
function new(string name="test",uvm_component parent);
//Build phase
env=environment::type_id::create("env",this);
seq1=seq::type_id::create("seq1",this);
//Run phase
phase.raise_objection(this);
seq1.start(env.agnt.seqcr);
phase.drop_objection(this);
`include "uvm_sd_test.sv"
module tb_top;
bit clk;
bit rst;
//clock generation
always #2 clk=~clk;
//reset generation
initial
rst=1;
#2 rst=0;
//Interface instance
intf vif(clk,rst);
//DUT instance
fsm1 DUT(.clk(vif.clk),
.rst(vif.rst),
.in(vif.in),
.out(vif.out),
.state(vif.state));
//Setting configuration database
initial
uvm_config_db#(virtual intf)::set(uvm_root::get(),"*","vif",vif);
$dumpfile("dump.vcd");
$dumpvars;
initial
run_test("test");
interface intf(input clk,rst);
logic [1:0] state; //Indicates the 2 bit states of transition in the fsm
logic in;
logic out;
endinterface
RTL
//RTL for FSM 1001 MEALY OVERLAPPING SEQUENCE DETECTOR
//Module for the input and output ports
module fsm1(clk,rst,in,out,state);
input clk,rst,in;
output out;
output [1:0] state;
reg [1:0] state,nextstate;
reg out;
//Clock block for resetting and state transition
always @ (posedge clk)
if(rst)
state=2'b00; //The state goes to reset state when reset is 1
state=nextstate; //next state becomes the current state when reset is 0
//Always block for state transition
always @(state or in)
case({state,in})
3'b000:begin
nextstate<=2'b00;
out<=0;
3'b001:begin
nextstate<=2'b01;
out<=0;
3'b010:begin
nextstate<=2'b10;
out<=0;
3'b011: begin
nextstate<=2'b01;
out<=0;
3'b100:begin
nextstate<=2'b11;
out<=0;
3'b101:begin
nextstate<=2'b01;
out<=0;
3'b110:begin
nextstate<=2'b00;
out<=0;
3'b111: begin
nextstate<=2'b01;
out<=1; //When the sequence is detected output becomes 1
endcase
COMPILE LIST
import uvm_pkg::*;
`include “uvm_macros.svh”
include "fsm1.sv" include “uvm_sd_interface.sv”
include "uvm_sd_seq_item.sv" include “uvm_sd_sequence.sv”
include "uvm_sd_sequencer.sv" include “uvm_sd_driver.sv”
include "uvm_sd_monitor.sv" include “uvm_sd_agent.sv”
include "uvm_sd_scoreboard.sv" include “uvm_sd_environment.sv”
`include “uvm_sd_tbtop.sv”
Can you be more descriptive beyond “My sequence isn’t driving at all”? What output are you seeing? What output do you expect to see? What do you think the issue is? An output transcript with the error(s) you are seeing is very helpful.
One simple issue is that your reset isn’t long enough. Try changing it from #2 to #20.
In reply to cgales:
106input=1State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 106: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 110: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
110input=1State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 110: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 114: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
114input=1State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 114: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 118: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
118input=0State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 118: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 122: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
122input=0State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 122: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 126: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
126input=1State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 126: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 130: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
130input=1State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 130: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 134: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
134input=1State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 134: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 138: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
138input=0State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 138: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 142: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
142input=0State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 142: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 146: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
146input=0State=xxOutput=x
UVM_INFO uvm_sd_monitor.sv(48) @ 146: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=00 Output=0
UVM_INFO uvm_sd_driver.sv(58) @ 150: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
150input=0State=xxOutput=x
In reply to cgales:
This is the output am getting now. but if the signals are driven, there should be state transition happening in my output. if you see my dut rtl, u could understand the way state transition happens. And regarding output, it should become 1 when the sequence 1001 is detected. In the waveform also state and output do not show at all. This is my problem.
yes, Reset isn’t long enough. here i am attaching code after increasing reset duration to 20 and it is working as per your expectations.
Link:-
Regards,
Mitesh
In reply to mitesh.patel:
Yes its working… Thanks a lot… but still the driver doesnt change and the scoreboard isnt displayed at all… what should i do for this?
Link:-
Edit code - EDA Playground
Regards,
Mitesh
really, thanks a lot for helping me out. I have been checking this for the past 3 days. It will be very helpful if you are able to help me out with driver and scoreboard. Thank you again
Because, write method from monitor is called outside the forever begin. ideally when, you sampled anything from interface it should be write to analysis port.
please find the link, it is showing packet received messages from scoreboard.
Link:-
Link:-
Thank you so much. It is very very helpful. Thanks a lot
Link:-
The input of driver and monitor changes. Could you please help me out with that?
I am also trying to correct it. Still a help would be supportive.
Can you please elaborate more? which inputs are changes ? i didnt get your question.
UVM_INFO uvm_sd_driver.sv(59) @ 38: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=11 Output=0
UVM_INFO uvm_sd_monitor.sv(48) @ 40: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=00 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(36) @ 40: uvm_test_top.env.sb [SB] Sequence is not yet started and so stays in reset state itself
UVM_INFO uvm_sd_driver.sv(59) @ 42: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
UVM_INFO uvm_sd_monitor.sv(48) @ 44: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(40) @ 44: uvm_test_top.env.sb [SB] Sequence is started and so it goes to the next state 01
UVM_INFO uvm_sd_scoreboard.sv(41) @ 44: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(59) @ 46: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=00 Output=0
UVM_INFO uvm_sd_monitor.sv(48) @ 48: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(45) @ 48: uvm_test_top.env.sb [SB] Sequence continues and it goes to next state 10
UVM_INFO uvm_sd_scoreboard.sv(46) @ 48: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(59) @ 50: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(48) @ 52: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=10 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(60) @ 52: uvm_test_top.env.sb [SB] Sequence is broken and so goes to state 01
UVM_INFO uvm_sd_scoreboard.sv(61) @ 52: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(59) @ 54: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=10 Output=0
UVM_INFO uvm_sd_monitor.sv(48) @ 56: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(50) @ 56: uvm_test_top.env.sb [SB] Sequence is broken and so stays in 01 state itself
UVM_INFO uvm_sd_scoreboard.sv(51) @ 56: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(59) @ 58: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(48) @ 60: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=01 Output=0
Packets received
Packets received
Packets received
Packets received
Packets received
Packets received
Packets received
Im getting output like this now. the driver and monitor should show the same output. But only the monitor shows the correct output. There is problem with driver clock i guess. but I am not able to identify it. Could you please help me with this?
UVM_INFO uvm_sd_monitor.sv(49) @ 94: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=00 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(44) @ 94: uvm_test_top.env.sb [SB] Sequence is started and so it goes to the next state 01
UVM_INFO uvm_sd_scoreboard.sv(45) @ 94: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 94: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=00 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 98: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(49) @ 98: uvm_test_top.env.sb [SB] Sequence continues and it goes to next state 10
UVM_INFO uvm_sd_scoreboard.sv(50) @ 98: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 98: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 102: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=10 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(64) @ 102: uvm_test_top.env.sb [SB] Sequence is broken and so goes to state 01
UVM_INFO uvm_sd_scoreboard.sv(65) @ 102: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 102: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=10 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 106: uvm_test_top.env.agnt.moni [MONITOR] Input=0 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(49) @ 106: uvm_test_top.env.sb [SB] Sequence continues and it goes to next state 10
UVM_INFO uvm_sd_scoreboard.sv(50) @ 106: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 106: uvm_test_top.env.agnt.dri [DRIVER] Input=0 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 110: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=10 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(64) @ 110: uvm_test_top.env.sb [SB] Sequence is broken and so goes to state 01
UVM_INFO uvm_sd_scoreboard.sv(65) @ 110: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 110: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=10 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 114: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(54) @ 114: uvm_test_top.env.sb [SB] Sequence is broken and so stays in 01 state itself
UVM_INFO uvm_sd_scoreboard.sv(55) @ 114: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 114: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 118: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(54) @ 118: uvm_test_top.env.sb [SB] Sequence is broken and so stays in 01 state itself
UVM_INFO uvm_sd_scoreboard.sv(55) @ 118: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 118: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 122: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(54) @ 122: uvm_test_top.env.sb [SB] Sequence is broken and so stays in 01 state itself
UVM_INFO uvm_sd_scoreboard.sv(55) @ 122: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 122: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=01 Output=0
UVM_INFO uvm_sd_monitor.sv(49) @ 126: uvm_test_top.env.agnt.moni [MONITOR] Input=1 State=01 Output=0
Packets received
UVM_INFO uvm_sd_scoreboard.sv(54) @ 126: uvm_test_top.env.sb [SB] Sequence is broken and so stays in 01 state itself
UVM_INFO uvm_sd_scoreboard.sv(55) @ 126: uvm_test_top.env.sb Got expected response
UVM_INFO uvm_sd_driver.sv(58) @ 126: uvm_test_top.env.agnt.dri [DRIVER] Input=1 State=01 Output=0
Packets received
Packets received
Packets received
Packets received
Packets received
Packets received
Packets received
Packets received
Packets received
I have corrected it to this extent. But the driver is displayed after monitor and scoreboard. How to make driver to display before monitor and scoreboard?
