A throughout B" is used to specify that property A holds continuously throughout the duration of property B. In other words, A is expected to be true for the entire time that B is true.
This is the waveform
I’m trying to make an assertion checker as the below,
But “Busy[*1:2] throughout DRdy” and “DRdy throughout Busy[*1:2]” are working differently.
why are CHK_BPE1 and CHK_BPE2 working differently?
property BPE1;
@(posedge clk)
(GntA) |=> DRdy throughout Busy[*1:2] ##0 Done;
CHK_BPE1 : assert property (BPE1);
property BPE2; 2
@(posedge clk)
(GntA) |=> Busy[*1:2] throughout DRdy ##0 Done;
CHK_BPE2 : assert property (BPE2);
user49
June 16, 2023, 5:55am
2
In reply to UVM_LOVE :
See my paper Reflections on Users’ Experiences with SVA, part 2 https://verificationacademy.com/verification-horizons/july-2022-volume-18-issue-2/reflections-on-users-e xperiences-with-sva-part-2 Addresses the usage of these four relationship operators: throughout, until, intersect, implies
Ben@systemverilog.us
or Cohen_Links_to_papers_books - Google Docs
In reply to ben@SystemVerilog.us :
Hi ben,
I understand the behavior of throughout.
During my years of contributions to the Verification Academy SystemVerilog Forum, I have seen many trends in real users’ difficulties in the application of assertions, and misunderstandings of how SVA works. In Part 1 of this article, I addressed the...
Thankfully… so I tried to another example.
Your text to link here…
property CHK02;
@(posedge clk)
$rose(idle) |=> stable(!reset) throughout (idle [*0: ] ##1 !idle ##1 idle);
CHK02_P : assert property (CHK02);
But this makes fail at 23NS. Could you give me a clue for resolve this?
user49
June 16, 2023, 3:30pm
4
SHould work per your waveform.
The throughout operator specifies that a signal (expression) must hold throughout a sequence. ( b throughout R ) is equivalent to ( b [*0:$] intersect R )
show your code
sorry for late Ben.
module Testbench;
// DUT signals
logic clk;
logic GntA=0;
logic Busy=0;
logic DRdy=0;
logic Done=0;
clk = 0;
// Instantiate assertion checkers
// Initialize signals
repeat(3)
@(posedge clk);
GntA = 1;
repeat(1)
@(posedge clk);
GntA = 0;
Busy = 1;
DRdy = 1;
repeat(1)
@(posedge clk);
Done =1;
repeat(1)
@(posedge clk);
Done =0;
Busy =0;
DRdy = 0;
repeat(14)
@(posedge clk);
// Finish simulation
#100;
$finish;
always #1 clk = ~clk;
$shm_open("wave.shm");
$shm_probe("AS");
property BPE1;
@(posedge clk)
property BPE2;
@(posedge clk)
From BPE1, I get the error " Expected a verilog expression as operand to throughout operator."
user49
June 17, 2023, 6:50pm
6
You have to look at the syntax!
1800’2017 page 378
sequence_expr ::=
| sequence_expr intersect sequence_expr
| sequence_expr or sequence_expr
| first_match ( sequence_expr {, sequence_match_item} )
| expression_or_dist throughout sequence_expr // <<<<<<<<<<<<
| sequence_expr within sequence_expr
The throughout requires an expression in the LHS
you have
Busy[*1:2] is a sequence
