I do came across checking a signal whether it is stable or not on a given clock edge, But How to write an assertion to check whether the clock itself is assigned to zero through out the simulation or not.
Regards,
Praveen
Regards,
Praveen
In reply to praveen1705:
You’ll need to tune this model to your requirements. Here I understood from your very brief requirement statement that you have a clock, but you want to detect if it is active (i.e., alive) and if it is stuck at 1 or at 0. The key to solving this is the fork join_any construct. If no clk, the non-alive block checks for values and uses immediate assertions.
module m;
logic clk;
bit alive;
initial forever #5 clk = !clk;
initial forever begin
am_alive: assert (alive==1) else $display("%t NOT ALIVE: clk==", $realtime, clk); //
@(posedge clk) alive=1'b1;
#20 alive=0;
am_X: assert (clk==1'b0 ||clk==1'b1) else $display("%t clk==", $realtime, clk); // is X or Z
am_1: assert (clk==1'b1) else $display("%t clk==", $realtime, clk); // is X or 0 or Z
join_any
// final procedure executes when simulat
final
am_1F: assert (clk==1'b1 && alive==1'b1) else $display("%t FINAL: clk==", $realtime, clk); // 0 X or Z
initial begin // test pattern
#100 clk <= 1'b1;
#100 clk <= 1'bX;
#100 clk <= 1'b0;
#100 clk <= 1'bZ;
#100 clk <= 1'b1;
Hi Ben,
Actually the problem statement is I have a clk which should be zero through out the simulation, If it goes to high at any point, then I do need to report it as an error.
Regards,
Praveen
always @(posedge clk) begin
am_1F: assert (0) else $display("%t Error: clk==", $realtime, clk); //
Ben
Thanks ben
