SVA to check clock toggling for a fixed number of cycles
I’m trying to write assertions for sclk to be stable and toggling for 4 clock cycles before ack goes high and stable and toggling 8 clock cycles after ack goes low. ack goes high after req is asserted, so that’s the 4 clock cycles delay for ack before it’s asserted.
property sclk_ack_req;
     @(posedge ref_clk) $rose(req) |-> sclk[*4] ##1 $rose(ack) ##3 $fell(ack) ##1 sclk[*8];
Please help me with this one, thanks.
In reply to foxtrot:
// sclk to be stable and toggling for 4 clock cycles
// Q: What is the definition of "stable"?
//    steady in value for 4 ref_clk cycles or
//    toggling for 4 sck cycles?   You mention both
// before ack goes high and stable and toggling 8 clock cycles after ack goes low.
// ack goes high after req is asserted, so that's the 4 clock cycles delay for ack before it's asserted.
// Q: Very poor defintion of the requirements.
//    Now you are talking about sclk to be a clock used as delay.
//    GIGO.  I don't understand your requirements.
// Above property says:
   // At the rose(req) you have sclk==1 for 4 consecutive ref_clk clock cyccles.
   // This is then followed by a rose(ack)and 3 ref_clk later ack fell.
   // This is then followed by sclk==1 for 8 consecutive ref_clk clock cyccles.
   // Note that $rose(ack) ##3 $fell(ack) does not cover the case of this sequence
  //  $rose(ack) ##1 ack==0 ##1 ack==1 ##1 ack==0
   // 0   1  x 1 0
   // to avoid this, you need
   // $rose(ack) ##0 ack[*3] ##1 $fell(ack)
  3. Papers:
sclk must be stable and toggling before ACK asserts (min 4 SCLKs)
 sclk must be stable and toggling after ACK de-asserts (min 8 SCLKs)
 sclk must be stable and toggling when both the REQ and ACK are asserted
Here you go, this is what I need to do.
// 0   1  x 1 0
  3. Papers:
Let’s consider your comment, I don’t want to check for sclk==1 for 4 clock cycles, but I want to check whether it’s toggling for 4 clock cycles. I’m unable to do that toggling part, this is where I need your help.
You have not described the relationship between ref_clk and sclk
How are they derived? Something like:
always_ff @(posedge sclk) begin
   ref_clk <= !ref_sclk;
// That relationship determines how you proceeed.  You may need multiclocking.
// ref_clk   ^  |  ^  |  ^  |  ^  |  ^  |  ^  |
// sclk      1     0     1     0     1
// req       0     1     x
// for the *4 repeat, perhaps something like this?
    bit v;
    @(posedge ref_clk)
       $rose(req) |-> @(ref_clk) (1, v=ref_clk)
                     ##0 (sclk==v ##1 sclk==!v)[*4]
    ##1 @(posedge ref_clk) $rose(ack) ##3 $fell(ack) ##1 sclk[*8];
GBGO, be more specific in your definition of requirements
Ben
