SVA to check clock toggling for a fixed number of cycles
In reply to foxtrot:
// sclk to be stable and toggling for 4 clock cycles
// Q: What is the definition of "stable"?
//    steady in value for 4 ref_clk cycles or
//    toggling for 4 sck cycles?   You mention both
// before ack goes high and stable and toggling 8 clock cycles after ack goes low.
// ack goes high after req is asserted, so that's the 4 clock cycles delay for ack before it's asserted.
// Q: Very poor defintion of the requirements.
//    Now you are talking about sclk to be a clock used as delay.
//    GIGO.  I don't understand your requirements.
property sclk_ack_req;
     @(posedge ref_clk) $rose(req) |-> sclk[*4] ##1 $rose(ack) ##3 $fell(ack) ##1 sclk[*8];
// Above property says:
   // At the rose(req) you have sclk==1 for 4 consecutive ref_clk clock cyccles.
   // This is then followed by a rose(ack)and 3 ref_clk later ack fell.
   // This is then followed by sclk==1 for 8 consecutive ref_clk clock cyccles.
   // Note that $rose(ack) ##3 $fell(ack) does not cover the case of this sequence
  //  $rose(ack) ##1 ack==0 ##1 ack==1 ##1 ack==0
   // 0   1  x 1 0
   // to avoid this, you need
   // $rose(ack) ##0 ack[*3] ##1 $fell(ack)
    Real Chip Design and Verification Using Verilog and VHDL($3) Amazon.com
  3. Papers:
