SVA: throughout corner case | sig1 must be stable throughout sig2
Hello,
I want to write an assertion that says ‘sig1 must be stable when sig2 is asserted’.
Here is my solution:
property sig1_stable_throughout_sig2 (logic sig1, sig2);
     $rose(sig2) |=> $stable(sig1) throughout !sig2[->1];
endproperty //sig1_stable_throughout_sig2
This assertion works very well, except for the case when sig1 exactly follows sig2 and deasserts in the same clock cycle as sig2.
My understanding is that the assertion requires that sig1 be stable even at the clock which deasserts sig1 (i.e at the negedge of sig1).
Is there a way to make the assertion run until one clock before sig2 deasserts? Or, any other way I could take care of this failure?
Ankit
     disable iff (!sig2)
Disabling the assertion when sig2 goes down seems to do the trick. Is this approach correct?
-Ankit
In reply to Ankit Bhange:
NO!
// The throughout operator specifies that a signal (expression) must hold throughout a sequence.
 ( b throughout R )[/b] is equivalent to [b]( b [*0:$] intersect R )
// Use the
sequenc1 interesect sequence2 // and sequence1 is
 ($stable(sig1)[*1:$] ##1 !sig2) // Thus, if sig2==0 after 4 cycles,
//                          the consequent thread that will match will be
 ($stable(sig1)[*3] ##1 !sig2 // sig2==0 at cycle 4
     $rose(sig2) |-> ##1 ($stable(sig1)[*1:$] ##1 !sig2) intersect !sig2[->1];
// As mentioned in a previous post, I prefer to use |-> ##1 instead |=>
// See my next post
  3. Papers:
Another option is to use the until
An until property of the non-overlapping form (i.e., until, s_until) evaluates to true if property_expr1 evaluates to true at every clock tick beginning with the starting clock tick of the evaluation attempt and continuing until at least one tick before a clock tick where property_expr2 (called the terminating property) evaluates to true.
property_expr1 until property_expr2
     $rose(sig2) |=> $stable(sig1) until !sig2; // Need the |=> because the until is a property
// same as
$rose(sig2) |=> $stable(sig1)[*0:$] ##1 !sig2; // also OK.
Thanks, Ben. The assertion seems to be working now.
Consider the following model where all 3 assertions are different. The annotated assertion thread viewer address cases that demonstrate why they are different. It is always preferable to test the assertions in a small model using constrained-random tests.
  timeunit 1ns;  timeprecision 100ps;
  `include "uvm_macros.svh"
  import uvm_pkg::*;
  bit clk, sig1, sig2;
  ap_sig1_stable_throughout_sig2 : assert property(@(posedge clk)
     $rose(sig2) |=> ($stable(sig1)[*1:$] ##1 !sig2) intersect !sig2[->1]);
  ap_until_sig1_stable_throughout_sig2: assert property(@(posedge clk)
     $rose(sig2) |=> $stable(sig1) until !sig2); // Need the |=> because the until is a property
  ap_sig1_stable_throughout_sig2_B : assert property(@(posedge clk)
    $rose(sig2) |=>  $stable(sig1) throughout (sig2[*1:$] ##1 $fell(sig2)) );
    repeat (200) begin
      @(posedge clk);
      if (!randomize(sig1, sig2) with {
        sig1 dist {1'b1 := 10, 1'b0 := 1};
        sig2 dist {1'b1 := 6,  1'b0 := 1};
        `uvm_error("MYERR", "This is a randomize error");
    $finish;
$rose(sig2) |=> (stable(sig1)[*1:] ##1 !sig2) intersect !sig2[->1]);
$rose(sig2) |=> stable(sig1) throughout (sig2[*1:] ##1 $fell(sig2)) );
  1. SVA Package: Dynamic and range delays and repeats https://rb.gy/a89jlh
  3. Papers:
Oops on comment for the last assertion
Google Photos
Hi
We usually use $stable(signa_name) to see a signal must be stable in from previous clk cycle. How to check that a signal must be stable within clk cycle
Thank you for the thorough explanation, Ben. It seems like
is what meets my requirements. However, for some reason I am getting a syntax error when trying to use the ‘until’ property. I think it is a tool issue.
Could you share any alternatives for until?
Ankit
An until property of the non-overlapping form (i.e., until, s_until) evaluates to true if property_expr1 evaluates to true at every clock tick beginning with the starting clock tick of the evaluation attempt and continuing until at least one tick before a clock tick where property_expr2 (called the terminating property) evaluates to true. The until, s_until operators have an implicit repetition until the terminating condition (i.e., property_expr2) occurs. Specifically, with a strong until (e.g., s_until), if the simulation completes but the terminating condition is pending, the assertion fails, unlike the weak until where the assertion is evaluated as vacuously true.
$rose(req) |=> busy until ready); // Enhanced readability, and Identical to
// $rose(req) |=> busy[*0:$] ##1 ready ; // equivalent property expression
// Thus,
// can be written as
     $rose(sig2) |=> $stable(sig1)[*0:$] ##1 !sig2);
// When sig2==0, sig1 need not be stable
