hcglu
July 15, 2021, 1:18pm
1
Hi Everyone,
I found answers of my many question from this forum, and until know I did not ask. Now, I have an confusing question, at least for me.
I am trying to pass seequence as a formal argument to a checker. I got this warnings, I used edaplayground, Mentor for simulation:
*** Error: testbench.sv(93): Use of unclocked sequence as an event is illegal.
** Error: testbench.sv(18): Illegal event value in SVA expression.
** Error (suppressible): testbench.sv(23): (vlog-1957) The sva directive is not sensitive to a clock. Unclocked directives are not supported.*
[i]
As I understand, it says I cannot find clock for sequence and it destroys my property block and assertion call. My code is here : SVA36 - Concurrent Assertions - 34 - Checker_3_X - EDA Playground
// Checker Block
//clock için başta event tanımı kullanıldı, bir tip. Olmasa da doğru çalışyıor.
//reset için ise event çalışmıyor, untyped ya da logic yazılmalı.
//checker içinde formal argument olarak sequence alınacak.
checker checker_1 (clock_delay,a,b,sequence sequence_1,event clk = $inferred_clock, /*untyped*/ logic reset = $inferred_disable);
// Declare property for each of sequence
// We may use more then one seuqnce in a property
property req_gnt_3to5clock_prop;
@ (posedge clk)
disable iff (reset)
//req[1] |-> req_gnt_3to5clock_seq;
a |-> sequence_1;
// Assertion Directive Layer
req_gnt_3to5clock_assert : assert property (req_gnt_3to5clock_prop)
$display("** Time : [%0t] - req_gnt_3to5clock_prop PASSED --------", $stime);
endchecker
// Checker Block
// DUT With assertions
module hash_sequence();
logic clk = 0;
always #1 clk ++;
logic [2:0] req,gnt;
logic reset=0;
//default clocking ve disable iff yapılıyor, checker bunlardan clock ve reset'i çekiyor.
default clocking @ (posedge clk); endclocking
default disable iff reset;
// Shows range usage of $ delay operator
sequence req_gnt_3to5clock_seq;
req[1] ##[3:$] gnt[1];
//a ##[clock_delay:$] b;
endsequence
// Drive the input vectors to test assetion
// Init all the values
reset <= 0;
for (int i = 0; i < 3; i++) begin
req[i] <= 0;
gnt[i] <= 0;
@ (posedge clk);
req[0] <= 1;
@ (posedge clk);
gnt[0] <= 1;
req[0] <= 0;
@ (posedge clk);
gnt[0] <= 0;
req[1] <= 1;
@ (posedge clk);
req[1] <= 0;
repeat(3) @ (posedge clk);
gnt[1] <= 1;
@ (posedge clk);
gnt[1] <= 0;
req[2] <= 1;
gnt[2] <= 1;
@ (posedge clk);
req[2] <= 0;
gnt[2] <= 0;
// Cause assertion to fail
@ (posedge clk);
req[0] <= 1;
repeat(2) @ (posedge clk);
gnt[0] <= 1;
req[0] <= 0;
#30 $finish;
//initialize checker check_1
checker_1 c1 (3, req[1] ,gnt[1],req_gnt_3to5clock_seq);
$dumpfile("dump.vcd");
$dumpvars;
Thanks…
user49
July 15, 2021, 3:32pm
2
In reply to hcglu :
I am not sure how well supported are the $inferred_clock, $inferred_disable because they are used that often.
Check with your vendor.
hcglu
July 15, 2021, 5:50pm
3
In reply to ben@SystemVerilog.us :
Thank you ben for your answer but I tried it and it works well.
Firstly, I use edaplaygorund and Mentor Questa 2020.1, it works fine.
Secondly, I tried seperately whether inferring clock and reset work or not, it works, I share the code: SVA35 - Concurrent Assertions - 33 - Checker_2 - EDA Playground
You will see it infers clock and reset from the block where it belongs to.
// Checker Block
//checker checker_1 (clock_delay,a,b, event clk = $inferred_clock, /*reg veya logic*/ untyped reset = $inferred_disable);
//input logic şeklinde daha açık girişler verilebilir.
checker checker_1 (input logic clock_delay, input logic a, input logic b, event clk = $inferred_clock, /*reg veya logic*/ untyped reset = $inferred_disable);
//req[1] ##[3:$] gnt[1];
endsequence
@ (posedge clk)
disable iff (reset)
a |-> req_gnt_3to5clock_seq;
endchecker
// Checker Block
logic clk = 0;
always #1 clk ++;
logic reset=0;
reset <= 0;
req[i] <= 0;
gnt[i] <= 0;
@ (posedge clk);
req[0] <= 1;
@ (posedge clk);
gnt[0] <= 1;
req[0] <= 0;
@ (posedge clk);
gnt[0] <= 0;
req[1] <= 1;
@ (posedge clk);
req[1] <= 0;
gnt[1] <= 1;
@ (posedge clk);
gnt[1] <= 0;
req[2] <= 1;
gnt[2] <= 1;
@ (posedge clk);
req[2] <= 0;
gnt[2] <= 0;
@ (posedge clk);
req[0] <= 1;
gnt[0] <= 1;
req[0] <= 0;
#30 $finish;
checker_1 c1 (3, req[1] ,gnt[1]);
$dumpvars;
In reply to hcglu :
Sorry, this is the first i see those system tasks. Is there any reason why you are using those ?
hcglu
July 15, 2021, 6:56pm
5
In reply to Rsignori92 :
Problem is not about these system taks. They work. You can pass directly clock or rest. Problem is about that I cannot pass srquence to checker but this is allowed according to LRM.
user49
July 15, 2021, 8:23pm
6
In reply to hcglu :
… " cannot pass srquence to checker"
That would be a tool limitation.
It’s not uncommon for a tool not to implement all the features of the language
hcglu
July 15, 2021, 9:06pm
7
I tried with other tools Synopsis aldec, Questa, it does not work.
Thank you Ben, I tackled many obstacles on my code with your and Dave posts.
In reply to hcglu :
I perfectly get your problem, my question was why you were using those tasks? (never seen before). Regards
hcglu
July 16, 2021, 11:30am
9
Iy is a differences between putting sequences and properties into a module or checker. If you use checker you can infer clock and reset from related block’s clock and reset. You can pass explicitely. In addition you can pass sequence to a checker but I could not.
I would choose to pass explicitly for making easy debugging and avoiding from complexity.
In reply to hcglu :
Perfect so there is no real reason or advantage why should be using those tasks instead of passing signals explicitly.
I believe you are using those along with the checker for reusability so, not for non deterministic modelling am i right? Just trying to get more from the usage you are doing. Regards
hcglu
July 16, 2021, 12:26pm
11
Exactly, increasing reusabllity and compactness. You can check LRM for more info.
In reply to hcglu :
That is exactly the reason why I asked you, the SV LRM 3.1a doesn’t mention it (unless I missed it while stepping into it). Usually, the properties are encapsulated in interfaces (fore reuse and encapsulation). So probably is an old approach? Just curious
hcglu
July 16, 2021, 3:15pm
13
It is not old approach Rsignorio92, you can find it in IEEE Std 1800™-2017 which is IEEE SystemVerilog Standard, 2017.
In reply to hcglu :
For some reason, the LRM I was looking at did not have it. Cool I found it in section 17. Thanks
