Can you explain the working of “==?” in
if(stage ==? 6'b1??1??)
//block of statements
stage is enum
stage is enum
In reply to asreeraj:
In general the wildcard comparison operator is used to make few bits in RHS as don’t-cares. The syntax you show above - is it part of casez/casex?
Regards
Srini
www.verifworks.com
Assume stage was declared with a typedef:
typedef enum logic [5:0] {S1=6'b100100, S2=6'b100111,S3=6'b100000} stage_e;
Then (stage ==? 6’b1??1??) would be true if stage had the value S1 or S2, and false for the value S3. If stage had the uninitialized value 6’bx, it would evaluate to false.
Thanks Dave. Can you name the operator ==?
Table 7-1: Wild equality and wild inequality operators
SystemVerilog_3.1aLRM
Operator :: Usage :: Description
=?= :: a =?= b :: a equals b, X and Z values act as wild cards
!?= :: a !?= b :: a not equal b, X and Z values act as wild cards
In reply to Ravi Nagadia:
Thanks Ravi
logic [2:0] j1 = 3'bxxx;
logic [2:0] j2 = 3'bzz1;
logic j3;
j3 = (j1==?j2);
$display("j3 = %0b",j3);
Output ::
# j3 = x
# ** Note: $finish : top.v(45)
# Time: 1050 ns Iteration: 0 Instance: /top
# End time: 10:45:40 on Jan 06,2017, Elapsed time: 0:00:01
# Errors: 0, Warnings: 7
In LRM :: The =?= and !?= operators treat X or Z as wild cards that match any value, thus, they too never result in X.
I am using questa 10.4c
I hope it resolved in latest releases.
The LRM does not say that. It does say
The == and != operators may result in x if any of their operands contains an X or Z. The**===** and !== operators explicitly check for 4-state values; therefore, X and Z values shall either match or mismatch, never resulting in X. The ==? and !=? operators may result in X if the left operand contains an x or Z that is not being compared with a wildcard in the right operand.
An X in a conditional if statement is treated as false.
