In C, we can easily use the directive as,
if MACRO_A == VALUE_A
But in SV, for example, is there a way to achieve this using below code?
`define NUM_OF_INS 2
`if NUM_OF_INS == 2
`else
`endif
Thanks.
`if NUM_OF_INS == 2
`else
`endif
Thanks.
In reply to kooder:
There is no equivalent text macro in SystemVerilog.
The workaround depends on what code you are intending to put in each branch.
Thanks.
Then what would the workaround be like if I want to put some code in branch if, e.g,
`NUM_OF_INS == 2
Should I define another macro like
`define NUM_OF_INS_TWO
I prefer doing conditional compile only per the value of `NUM_OF_INS.
In reply to kooder:
If you had the code
if (`if (`NUM_OF_INS == 2) begin
signal1 <= 5;
end else begin
signal2 <=7;
== 2) begin
signal1 <= 5;
end else begin
signal2 <=7;
That would work as long as NUM_OF_INS was always defined to be some integer expression. But like I said before, you need to show what you are trying to accomplish.
Yeah, my code looks like below,
`if `NUM_OF_INS == 2
assert property (@(posedge clk) bb_seq |=> bb_exp[0] == bb_rtl[0]);
assert property (@(posedge clk) bb_seq |=> bb_exp[1] == bb_rtl[1]);
`else if `NUM_OF_INS == 1
`endif
If NUM_OF_INS==2, two assertions are compiled, and if If NUM_OF_INS==1, only one assertion will be compiled. However, it seems SV only support directives like ifdef, but no if, so I have no idea on how to do conditional compile according to the value of the macro.
In reply to kooder:
There’s no need of a macro to do this. You can use an if, case, or for loop.
end else if (`NUM_OF_INS == 1) begin
See section 27 Generate constructs in the 1800-2017 LRM
Cool~ Thank you!
I am facing similar problem. But a little difference is there. Based on macro value I have to compile different testcases
As follows
ifdef VALUE equals 1 include “testcase_1.sv”
elsif VALUE equals 2 include “testcase_2.sv”
`endif
Thanks in advance
In reply to rithu_km:
If VALUE is being defined on the command line, it would be much easier to handle this in the compilation script or Makefile.
Otherwise you could do:
`define VALUE 1
`define QCONCAT(v1,v2) `"v1``v2.sv`"
`include `QCONCAT(testcase_,`VALUE)
Fixed it in Makefile itself.
Thanks for the reply
I’m trying to update a condition with MACRO value :
OpIsSequencer = (opcode == MATH) | (fmt = DF && (`RATE==SLOW));
In the above code RATE is a config parameter which can change to SLOW, FAST, MED
I’m facing compilation error for the same.
Kindly help fix this issue.
