How to combine sv assertions to submodules of DUT in UVM testbench and able to switch assertions off
I would like to know if possible from “uvm testcase” class to have a path back to the DUT submodules in order to switch off assertions. Because assertions are based on sub-module of DUT, the goal is to switch off assertion depends on the test.
DUT module:
module dut_module(
input wire clk,
input wire reset,
example_module example_module_u
.example_clk (clk),
.example_count (count),
.example_enable (enable),
.example_ack (ack)
endmodule;
//assertion module
module ust_example_assertions #(parameter parameter1)(
//port declartion for the example module
input wire example_clk,
input wire [parameter1-1:0] example_count,
input wire example_enable,
input wire example_ack);
assert_name: assert property(@(posedge example_clk)!(example_enable && example_ack && example_count > 17’h0_1000))
$fatal(1,“FATAL: This transaction is invalid in %m at %0d ps.”, $time);
endmodule:ust_example_assertions
//testbench top:
Bind example_module example_assertions#(.parameter1(parameter1)) inst_assert(.*);
//uvm testcase
class example_test extends uvm_test;
task run_phase(uvm_phase phase)
$assertoff(1, path to the DUT submodule) //something similar
Chao
In reply to cw948:
Use below and check:
bind dut_file assertion_file(.assertion_signal(dut_signal));
First comment the $assertoff and run above, if everything is fine then remove comment.
-Sunils
In reply to sunils:
Hi Sunil,
Sorry, it doesn’t work for me. The problem is having $assertoff(0) in the testcase unable to switch off assertions. So I thought by giving direct path to the DUT sub-module might help, but what is the path from uvm testcase to DUT submodule?
Chao
In reply to cw948:
The path is hierarchical like given below:
$assertoff(0,tb_top.inst_dut);
There are two arguments, first is zero and secondly we are accessing the dut submodu
le from tb top file. inst_dut is instance fo dut submodule in the tb top file.
–Sunils
In reply to sunils:
Don’t use $assertoff() statements. They are messy and require code changes/recompilation to change the testbench behavior.
Instead, you should be using your simulation tool’s method for disabling assertions. Each simulator has a unique way of doing this, so you will need to read your tool’s user manual.
Another option is to put the bind statements in a separate top-level module. You can disable all of the assertions associated with the bind statements by not simulating that module.
In reply to sunils:
Hi sunils and cgales,
Thank you for the reply.
But the problem is the verification environment I’m working on is UVM testbench, how can I switch assertions off in testcase class or in testcase class access to testbench top?
Chao
In reply to cw948:
There is no restriction, you can use the simulator features to switch off/on the assertions.
Doing this from your UVM testbench/test code is more restrictive.
