I’m driving this with a task, but with variable amount of delay after each drive
task automatic send();
forever begin
cb.wren <= 0;
while (!cb.ready) @cb; // Wait until ready
cb.wren <= 1;
cb.data <= some_data;
@cb;
cb.wren <= 0; // Clear
// Insert some random delay
repeat($urandom_range(0, 10)) @cb;
The issue I have is that when cb.ready is asserted, it takes the testbench at least one cycle to respond. I want to be able to cover the case where wren is asserted combinationally in the same cycle as ready.
One way to overcome this, is to use “input #0 ready” in the clocking block. However, I’ve been told that this is a bad idea.
What’s the correct way to do this? Even better, what’s the right way to insert randomized delays of >=0 cycles while driving the dut?
I doubt you can overcome this situation with “One way to overcome this, is to use “input #0 ready” in the clocking block. However, I’ve been told that this is a bad idea.” this. Have you tried this?
To drive wren signal on same cycle where ready is asserted, you’ll have to bypass clocking block. And use wait construct for ready high condition. However if your spec refers to synchronous signals, you might be missing something in driving protocol. As for synchronous designs you should be able to achieve handshakes through clocking block, which is not case here.
Also, your randomized delay approach works ok, but if you want control on randomization as well, use packet based delays with constraint randomization.
In reply to bitfiddler0:
Yes I have tried “input #0 ready” and it works for this particular circuit I’m testing.
Can you elaborate on what you mean by “However if your spec refers to synchronous signals, you might be missing something in driving protocol” ?
Not sure how making input skew Zero for ready signal solves the problem, as clocking block will sample 0step before clock edge or 1step based on input skew. But still there no way to achieve driving of ready/wren at same point where both the signal comes from two opposite blocks, testbench and design.
For synchronous handshakes either your testbench environment should wait for ready signal(sampled in testbench on clock edge, using clocking block). In which there will be a One cycle delay between ready/wren. Or testbench drives wren independently regardless of ready signal, but needs to hold wren until ready high is sampled, which means design accepted the wren signal. This is similar to AHB protocol minus pipeline.
In reply to MayurKubavat:
You should not be using any input or output skews unless your DUT is a gate-level design with timing. Use the implicit default, or write
default input #1step output #0;
Your while loop is effectively double sampling ready. Try
Yes I understand how a handshake would work with clocking blocks, but in this module (it’s just a fifo), it is illegal to assert wren unless the DUT is ready.
Thanks for the information. I think I have never tried #0 input skew, and misinterpreted the behavior! Also I don’t see any reason to not use #0 skew with RTL.
Do not to that! Never mix blocking event statements that are not synchronized to the clocking block event with the clocking block event. Another way to put that is once your process is synchronized to a clocking block event, only use the clocking block event. Otherwise you can easily get race conditions when waiting for the first @cb event after an unsynchronized event.
Hi…i am a new user here. As per my knowledge it takes the testbench at least one cycle to respond. I want to be able to cover the case where wren is asserted combinationally in the same cycle as ready. Use “input #0 ready” in the clocking block.
