Assertion on clock gating
I am trying to write assertion to check clock gating feature.
Whenever my clk_gate_cfg is 0 my clk will stop after 2:3 cycle for the particular block and will remain stop/zero till clk_gate_cfg will not assert.
Like in my env i have reg “clk_gate_cfg” .It has 8 bit register.
I have wrote below assertion for the above requirement. Please let me know where i am doing wrong.
This assertion is passing in every cases.
property clk_gating
@(posedge top_th.ref_clk)
((top_th.abc.abc_core.cfg_reg.clk_gate_cfg[1] == 0) ##[2:3]  (!top_th.abc.abc_core.trif_core[1].clk_i)) |->  top_th.abc.abc_core.trif_core[1].clk_i ==0 throughout (top_th.abc.abc_core.cfg_reg.clk_gate_cfg[1]==1)[->1]
In reply to kuldeep sharma:
I see your requirements as:
//Whenever my clk_gate_cfg is 0 my clk will stop after 2:3 cycle
// for the particular block and will remain stop/zero till clk_gate_cfg will not assert.
// Like in my env i have reg "clk_gate_cfg" .It has 8 bit register.
property clk_gating
  $fell(top_th.abc.abc_core.cfg_reg.clk_gate_cfg[1]) |->
  ##[2:3] top_th.abc.abc_core.trif_core[1].clk_i ==0 [*1:$] intersect
                (top_th.abc.abc_core.cfg_reg.clk_gate_cfg[1]==1)[->1];
  3. Papers:
Hi Ben,
Thanks for the reply. I have few queries.
How many times Assertion print will come ?
Or Will it come when "clk_gate_cfg[1]==1) ?
Above assertion is not failing when i am doing clock disable for fist bit and checking clock for another block .In my desgin 1 bit is gating clock for 1 instance of core. Like
property clk_gating
fell(top_th.abc.abc_core.cfg_reg.clk_gate_cfg[1]) |-> ##[2:3] top_th.abc.abc_core.trif_core[2].clk_i ==0 [*1:] intersect
I went overboard on the use of the intersect
 // !a[*1:$] intersect a[->1] should fail
 // !a[*1:$] ##1 a intersect a[->1] // ok
  // but then you don't need the intersect
  ##[2:3] top_th.abc.abc_core.trif_core[1].clk_i ==0 [*1:$] ##1
                (top_th.abc.abc_core.cfg_reg.clk_gate_cfg[1];
Clarify your comments
Am not reading the requirements correctly, but you get the ideas of options.
Hopefully it’s a guide
BTW, in the consequent you should consider it first_match.
first_match(##[1 ;2] b)##1 c
You could also implement a cntr on the clk you are trying to check and then check something like this in your assertion : cntr==$past(cntr)
Hi @user49
What this represent in your code"[->1]"
property clk_gating
a[->1] is equivalent to !a[*0:$] ##1 a
