This parameterized class can use typedefs defined in one of its parameter classes via a typedef, but cannot use the parameter class typedef directly to declare a member variable.
class m0s8xyz_env #(type P, type V) extends ovm_component;
// Define type using parameter class typedef.
typedef V::bus_loopback_vif_t v_bus_loopback_vif_t;
// Member variable declaration using local typedef works
v_bus_loopback_vif_t bus_loopback_vif;
// Member variable declaration using parameter class typedef fails
//V::bus_loopback_vif_t bus_loopback_direct_vif;
Why does use of a parameter class typedef work in a typedef but fail in a variable declaration?
Because the compiler needs to know that V::bus_loopback_vif_t is type in order to parse the variable declaration syntax. The parser does not know what kind of statement you are trying to write because it has no idea what kind of identifier bus_loopback_vif_t is. When you use the typedef keyword, the parser knows that the next token must be a type (eventually), and can parse the variable declaration using the local type. You will get an elaboration error if after parametrization, V::bus_loopback_vif_t does not turn out to be a type.
You should be able to use the following to avoid a local typedef:
All type identifiers must be declared as a type before they can be referenced as a type. You can declare an identifier as a type by using a typedef, forward typedef, type parameter, or type() operator.
The examples above V is known as a type because it is declared as a type parameter. Its specific type is unknown until after elaboration.
The result of type(V::bus_loopback_vif_t) is always a type, regardless of whether bus_loopback_vif_t is actually a type, variable or parameter.
class env #(type P, type V);
type(V::bus_loopback_vif_t) bus_loopback_direct_vif;
class B;
typedef int bus_loopback_vif_t;
endclass // B
env#(int,B) e;
// Test type operator
class B;
env#(int, B) e;
I get these messages
QuestaSim vlog 10.2a Compiler 2013.03 Mar 15 2013
– Compiling package test_sv_unit
** Error: test.sv(4): Type-reference expression may not have hierarchical refs. or elements of dynamic types.
– Compiling module top
It turns out I was using a slightly different example that still had your local typedef in it, so the type() operator would always work. Once I removed the typedef, the version of Questa I was using caught the error at a later stage of elaboration after vlog. I thought this would work, but I’ll have to investigate it further.
