VHDL code:
type t_x is record
row: integer range 0 to 1023;
size: integer range 0 to 1023;
end record;
type x_array is array(7 downto 0) of t_x;
please provide
equivalent System Verilog code
VHDL code:
type t_x is record
end record;
please provide
In reply to Mallikarjun79:
You have two options:
class R;
/* VHDL code:
type t_x is record
end record;
type x_array is array(7 downto 0) of t_x; */
bit[0:9] row, size;
rand bit[0:9] rw, sz;
package my_pkg;
typedef struct {
bit[0:9] row, size;
} t_x;
endpackage : my_pkg
module m;
import my_pkg::*;
t_x mrz; // from the package
R r;
bit clk, a;
bit[0:9] w, q;
initial forever #10 clk=!clk;
r=new();
w=1023; q=70;
r.row=w;
r.size=q;
mrz.size=1023;
mrz.row=15;
if (!randomize(r) with
{ r.rw > 5; w <70;
r.sz > 1; r.sz < 14;}) $error("randomization error");
Both VHDL code and SV code will be in package.
VHDL code.
type t_x is record
end record;
SV code.
typedef struct {
int row, size;
} t_x;
My question is
How to declare the array of type t_x variable?
typedef t_x_array[0:7] t_x;
When tried this it is saying that t_x_array is unknown type.
please provide equivalent SV code for this (type x_array is array(7 downto 0) of t_x;)
The syntax is
typedef t_x x_array[7:0];
Note that some tools will allow you to share types in packages between VHDL and SystemVerilog so you only need to declare them in one package. Check your user manual.
Hi All,
In VHDL Record is there for combining two or more signals/ports and we can call the records in a single name of representation.
So in Verilog is there any equivalent keyword for the same.
Thanks in Advance PHP Training in Chennai | Web Designing Training in Chennai
In reply to acemaria90:
In SystemVerilog, you can use the SystemVerilog interface to combine signals/ports. The interface is actually far more powerful than the VHDL record, as you can include functions, tasks, assertions, and computations with signal assignments and clocked procedures. The original Verilog does not support this capability; SystemVerilog is inclusive of Verilog.
The direct equivalent of a VHDL record is a SystemVerilog struct. An interface is certainly much more powerful as Ben states that gives you almost class-like functionality, but a struct may be more appropriate in many cases.
hello
I am trying to assign a signal from in-depth VHDL DUT hierarchy ot type
type mif_fifo_status_t is record
a : unsigned( 4 downto 0);
b : unsigned( 3 downto 0);
c : unsigned( 4 downto 0);
end record;
to a SV variable in the test bench of ttpue
typedef struct packed {
logic unsigned [4:0] a;
logic unsigned [3:0] b;
logic unsigned [4:0] v;
} mif_fifo_status_t;
same type name, same field type and size
this.status = $root.tb.i_dut.carrier_a_block.i_a_h_hm2.i_hm_core.i_fifo_monitor.i_fifo1_i.mif_fifo_statu;
types are compiled in VHDL and verilog from two different files
I get
whatt’s wrong here?
thanks
In reply to stanzani:
SystemVerilog requires that structures have to be derived from the same type definition to be assignment compatible. It is not good enough to give two types the same name and same layout.
Please consult your tools User Manual as sharing types for mixed language simulations is a tool specific feature.
vhdl code
type element;
type element_ptr is access element;
type element is
record
s1 : std_logic_vector(PAGE_ID_WIDTH-1 downto 0);
s2 : std_logic_vector(TAG_ID_WIDTH-1 downto 0);
age : time;
ptr1 : element_ptr;
end record;
Can you help me convert this vhdl into sv i am facing some error.
What i have done is…
SystemVerilog code
typedef struct element;
typedef element element_ptr;
typedef struct {
logic [PAGE_ID_WIDTH-1:0] s1;
logic [TAG_ID_WIDTH-1:0] s2;
time age;
element_ptr ptr1;
} element;
SystemVerilog does not have pointers to arbitrary variables. The most direct translation of this code would be to use a class
class element;
time age;
element ptr1;
However, if the purpose of element is building a linked list, you could use a queue of structs instead of a class.
