Hello I am facing some issues with a clock agent I made .
This agent has a clk interface and runs by a clock_sequence which is started in test.
Now I have two more interfaces in top file viz.
In the above instantiation clk_interface is set (uvm_config_db)in top file itself . Other two interfaces are also set in the top file itself . The other two interfaces need a clk and rst for internal SV clocking blocks. This is not working .
NOW clk_interface is working fine with DUT . clk_seqs provides clock to DUT . But other sequences which is running for other two interfaces and provides other data items to their respective drivers is not working because clock is not inferred in the top file to their interfaces. Any ideas on How to solve this ??
I am open to changing my environment Once I get some clarity on
If I use a clk agent . clk’s logic is in clk_seqs . SAME clock and rst should be inferred on other two interfaces.
Its necessary for me use the same clock agent as their are many clocks with many functionalities in that agent .
If I get more information on How to use clock agent properly without a seqs , that is also acceptable .
Thank you . Any help is appreciated.
In reply to sarth21:
In your question I do not understand what you mean with ‘In the above instantiation clk_interface is set (uvm_config_db)in top file itself’.
In any way you need an instance of your clock interface like this
sv_clk_interface clk_interface();
Does this exist?
Yes it does exist. I meant that clk_interface is set using uvm_config_db in top file and get I’m env - then agent and then in driver. This is done because logic for clock is driven by a sequence. So to satisfy vif.clk <= req.clk.
What I want is the clock which I am giving from a sequence should be inputted in other interfaces (above mentioned).
So clk is reflected in clk_interface and DUT. But not in another interfaces. Same clk is needed in other interfaces as it has SV Clocking blocks.
If the DUT is connected to the clk_interface and it works then the clk_interface should have been connected to all relevant signals. Did you check the waveforms of the clk_interface and the other interfaces?
Here I am just giving an initial value for clock and reset . Following is driver code
task run_phase (uvm_phase phase);
REQ req ;
drive_rst(req);
drive_clk(req);
seq_item_port.item_done(req);
//Drive clk task
task drive_clk(REQ req);
logic init_clk_value ;
logic phase_shift ;
logic half_period ;
init_clk_value = req.init_clk ;
phase_shift = req.phase_shift ;
half_period = req.period/2 ;
if(phase_shift)begin
#phase_shift;
vif.clk = init_clk_value ;
forever begin
vif.clk = #half_period ~vif.clk ;
join_none
//Drive rst task
task drive_rst(REQ req);
logic rst_val ;
rst_val = req.init_rst ;
@(posedge vif.clk)
#1step;
vif.rst = rst_val ;
join_none
Now I know forever loop is causing following errors
//Iteration limit reached 10000 at time 0 ns ;
Is there any other way to drive clk and rst properly throughout the simulation ?
But keeping a separate agent for now is necessary.
