I"m new to using assertions and I was going through some best practices paper from a website. The below assertion compiles fine.
always @* begin
ERR_reset_went_unknown: assert(!$isunknown(Reset))
else begin
$error("ERR_reset_went_unknown");
repeat(2) @(posedge Clock);
$finish;
However, if I remove the else portion, I get a compile error.
always @* begin //The always @* trigger will also catch the 0-to-X/Z-to-1 transitions
assert(!$isunknown(Reset));
** Error: counter_asserts.sv(27): ‘ERR_reset_went_unknown’ already exists; must not be redefined as a named block
If I remove the label, ERR_reset_went_unknown:, above it compiles.
Why is this?
In reply to markylew:
All assertions labels must be unique.
Also, watch the syntax and the use of the end of statement “:”.
module m;
bit Reset, clock;
always @* begin
else $error("ERR_reset_went_unknown");
always @* begin
ERR_reset_went_unknown2: assert(!$isunknown(Reset));
// else $error("ERR_reset_went_unknown");
ERR_reset_went_unknown3: assert(!$isunknown(Reset));
repeat(2) @(posedge clock);
$finish;
You have to look at the syntax. 1800’2018 16.3 Immediate assertions
immediate_assertion_statement ::=
simple_immediate_assertion_statement
| deferred_immediate_assertion_statement
simple_immediate_assert_statement ::=
assert ( expression ) action_block
action_block ::=
statement_or_null
| [ statement ] else statement_or_null
ERR_reset_went_unknown: assert(!$isunknown(Reset)) // assert ( expression )
else $error("ERR_reset_went_unknown"); // [ statement ] else statement_or_null
// note that from the syntax on the action_block the [statement] is optional.
// thus, thus the following is in ERROR
assert(!$isunknown(Reset)); else $error("ERR_reset_went_unknown");
// because
assert(!$isunknown(Reset)); // this follows the syntax of
assert ( expression ) null; // The ";" is the end of simple_immediate_assert_statement
// so what you have
assert(!$isunknown(Reset)); // a legal statement, DONE here with that statement
else $error("ERR_reset_went_unknown"); // else? no legal statement starts with "else'
// what is that funny "else' statement? It's hanging there!! illegal!
