I’m trying to write a property to check a signal that behaves with the following requirements
1- signal ‘a’ should be high for a number of cycles (first_hi)
2- After that signal ‘a’ should go low for a number of cycles (first low)
3- Following that ‘a’ should go high again for a number of cycles (second_hi)
4- Finally ‘a’ should go low for a number of cycles (second_lo)
I have very little knowledge on SVA syntax and most of the times I get confused with writing SVAs that actually work, so far my assertion looks like this Version 1:
I tried to create a module to test both implementations (both are failing) but from what I can see from the waveform the signal has the correct behaviour
In reply to rgarcia07:
Several issues with your assertion:
a[*first_hi] ##0 $fell(a) // using "a" instead of signal
//This sequence is always a no match, regardless of the values of the repeat.
//For simplicity, let first_hi==1. Now you have as a sequence
(a[*1] ##0 fell(a) // or more simply
a ##0 fell(a) // and that says that in the very SAME cycle, a==1 and a==0
// What you need is
a[*first_hi] ##1 $fell(a)
// Your property would then read
property double_beat_signal_check(clk, areset_n, signal, first_hi, first_low, second_hi, second_low);
@(posedge clk) disable iff(!areset_n)
$rose(signal) |-> signal[*first_hi] ##1 $fell(signal) ##1 !signal[*first_low]
##1 $rose(signal) ##1 signal[*second_hi]
##1 $fell(signal) ##1 signal[*second_low];
A second issue is that depeding upon the values of the repeats, a 2nd attempt of the assertion may fail. An attempt ocurs at every $rose(a) in this property. For example:
Use nonblocking assignments (e.g., db <= 1’b1;)instead of blocking blocking assignments. SystemVerilog is very loose in the syntax, but to avoid issues, it is always best to use best practice and recommended rules.
There are cases where directed tests are needed. However, in most cases it is easier, faster, and probably better to use constrained-random tests. For this, I use the following template stored in PhaseExpress application https://www.phraseexpress.com/ You need to modify the constraints to fit the needs.
PhraseExpress is a text expander software, that manages frequently used text templates for insertion into any program. It is free for personal use. I highly recommend it.
timeunit 1ns/100ps;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit clk, a, b;
default clocking @(posedge clk);
endclocking
initial forever #10 clk=!clk;
$timeformat(-9, 1, "ns", 8);
$display("%t", $realtime);
always @(posedge clk) begin
bit va, vb;
repeat(200) begin
@(posedge clk);
if (!randomize(va, vb) with
{ va dist {1'b1:=1, 1'b0:=3};
vb dist {1'b1:=1, 1'b0:=2};
}) `uvm_fatal("RAND", "This is a randomize error")
#1; a <= va;
b <= vb;
$stop;
