I have a signal ‘a’ asserts and then after 10 clock cycles signal’b’ assets(stays high for one clock cycle).Once signal ‘b’ asserts after 10 clock cycles signal ‘c’ shall never assert(signal ‘c’ is by default ‘0’)
I had written like below
If you want to test an assert statement about option 2.
// Option 2
property exp;
@(posedge clk) disable iff (~resetn)
$rose(a) |-> (##[1:10] $rose (b)) #-# always (c !== 1'b1);
a_exp : assert property (exp) else $fatal("error in assertion");
// The #-# is the followed-by operator.
What approach is proper for you? I want to learn from it.
I prefer option 2 because the assertion will fail if rose(a)==1 and rose(b) does not occur within 10 cycles.
To test it, write a TB with a small set of directed test vectors.
Ben
In reply to UVM_LOVE:
Thank you for your interest in SystemVerilog directed tests. It’s a fundamental skill for working with hardware design and verification. If you’re not familiar with writing simple directed tests in SystemVerilog, I encourage you to explore online resources and tutorials to enhance your understanding. There are many helpful guides available that can provide step-by-step instructions. Developing a strong foundation in this area will greatly benefit your work in the field. Best of luck with your learning journey!
After that, you should start studying constrained-random-tests (CRT), but this is another story.
If signal ‘c’ shall not assert only for sometime how to add clock cycles to always?
Your question is ambiguous.
signal c==0 for 30 clocks and then c is a don’t care.
($rose(a) |-> ##[1:10] $rose (b)) #-# s_always[0:19] (c !== 1’b1);
signal c==0 for unknown number of cycles until it becomes 1 once
$rose(a) |-> ##[1:10] $rose (b) ##1 c[->1]
signal c==0 for unknown number of cycles until it becomes 1 once;
it then stays a c==0
$rose(a) |-> (##[1:10] $rose (b) ##1 c[->1]) #-# always (c !== 1’b1);
