System verilog assertion on asynchronous signals
I wanted to write an assertion to check the “out” signal follows the “in” signal when “dat” is equal to check. Both “in” and “out” are not synchronous to the “clk” .The only condition is it should ignore the pulse while “dat” is changing from no check to check and vice versa as I highlighted with the red ink .
In reply to DChal:
You can use the following as a baseline. Note that as long as dat==ccheck, “a” must follow “b”.
See the notes on my assumptions.
    timeunit 1ns / 100ps;
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    bit clk, a, b, dis;
    int dat, check;
    // There is a need to define which time zone to reject.
    // For this model, I am assuming that the zone to rejet is 3ns
    // after dat!check
    // During check, "b" must follow "a" within 2ns
    // Am assuming that "a" occurs first ar at the same time as "b"
    always begin
        @(dat != check)  begin
            dis=1'b1;
            #3;
            dis=1'b0;
    property p_ab;
        realtime t;
        disable iff(dis)
        @(a) (check==dat, t=$realtime) |-> @(b) $realtime-t <2ns &&  $realtime-t >=0;
    ap_ab: assert property(p_ab);
      repeat (200) begin
        @(posedge clk);
        if (!randomize(a, b, dat, check) with {
          a dist {1'b1 := 1, 1'b0 := 1};
          b dist {1'b1 := 1, 1'b0 := 2};
          dat dist {2 := 1, 3 := 2};
          check dist {2 := 1, 3:= 1};
          `uvm_error("MYERR", "This is a randomize error");
      $finish;
  3. Papers:
Hi Ben ,
Thanks for replying , I understand that your solution accounts for the pulse rejection when dat is changing from no-check to check , but the other case is it changing from check to no-check which is the second red marker the image.
How can I handle that case ? May be I misunderstood you answer .
In reply to DChal:
This model is an improvement, but it still has issues.
    import uvm_pkg::*;
    bit clk, a, b, dis, check_mode;
    int dat, check;
    initial forever #3 clk = !clk;
    // after dat!check
    // Extending the property by 1 or 2 or @(posedge clk)  with
    //  ##1 @(posedge clk) 1'b1 ##1 @(posedge clk) 1'b1;
    // allows a disable to occur if (dat != check) soon after
    always begin
            dis=1'b1;
            #3;
            dis=1'b0;
    always_comb  check_mode= (dat == check);
    property p_ab_pos;
        realtime t;
        disable iff(dis)
        @(posedge a) (check==dat, t=$realtime) |-> @(posedge b) $realtime-t <2ns &&  $realtime-t >=0
                                      ##1 @(clk) 1'b1; // ##1 @(clk) 1'b1;
    ap_ab_pos: assert property(p_ab_pos);
    property p_ab_neg;
      realtime t;
      disable iff(dis)
      @(negedge a) (check==dat, t=$realtime) |-> @(negedge b) $realtime-t <2ns &&  $realtime-t >=0
                                    ##1 @(clk) 1'b1; // ##1 @( clk) 1'b1;
  ap_ab_neg: assert property(p_ab_neg);
      repeat (200) begin
        repeat(2) @(posedge clk);
          dat dist {2 := 1, 3 := 5};
          check dist {2 := 1, 3:= 7};
      $finish;
  3. Papers:
Thank you Ben , will try something similar !
In reply to DChal:
A second update that addresses the value of “b” follows “a”. The previous answer addressed the transitions but the values. Note that it can be solved with one assertion using the @(a), @(b) instead of the @(posedge a), @(posedge b).
    import uvm_pkg::*;
    int dat, check;
    // after dat!check
    always begin
            dis=1'b1;
            #3;
            dis=1'b0;
    property p_ab_pos;
        realtime t;
        bit a_sampled;
        disable iff(dis)
        @(posedge a) (check==dat, t=$realtime, a_sampled=a) |->  //
                     ##0 a_sampled==b //  @(posedge b) the "b" is its sampled value
    property p_ab_neg;
      realtime t;
      bit a_sampled;
      disable iff(dis)
      @(negedge a) (check==dat, t=$realtime, a_sampled=a) |->
                    ##0 a_sampled==b //  @(negedge b) the "b" is its sampled value
    property p_ab_pos_neg;
      realtime t;
      bit a_sampled;
      disable iff(dis)
      @(a) (check==dat, t=$realtime, a_sampled=a) |->  //
                   ##0 a_sampled==b //  @(b) the "b" is its sampled value
  ap_ab_pos_neg: assert property(p_ab_pos);
      repeat (200) begin
      $finish;
Ben
