System verilog assertion on asynchronous signals
In reply to DChal:
You can use the following as a baseline. Note that as long as dat==ccheck, “a” must follow “b”.
See the notes on my assumptions.
module top;
    timeunit 1ns / 100ps;
    `include "uvm_macros.svh"
    import uvm_pkg::*;
    bit clk, a, b, dis;
    int dat, check;
    initial forever #10 clk = !clk;
    // There is a need to define which time zone to reject.
    // For this model, I am assuming that the zone to rejet is 3ns
    // after dat!check
    // During check, "b" must follow "a" within 2ns
    // Am assuming that "a" occurs first ar at the same time as "b"
    always begin
        @(dat != check)  begin
            dis=1'b1;
            #3;
            dis=1'b0;
    property p_ab;
        realtime t;
        disable iff(dis)
        @(a) (check==dat, t=$realtime) |-> @(b) $realtime-t <2ns &&  $realtime-t >=0;
    ap_ab: assert property(p_ab);
      repeat (200) begin
        @(posedge clk);
        if (!randomize(a, b, dat, check) with {
          a dist {1'b1 := 1, 1'b0 := 1};
          b dist {1'b1 := 1, 1'b0 := 2};
          dat dist {2 := 1, 3 := 2};
          check dist {2 := 1, 3:= 1};
          `uvm_error("MYERR", "This is a randomize error");
      $finish;
    Real Chip Design and Verification Using Verilog and VHDL($3) https://rb.gy/cwy7nb
  3. Papers:
