SVA : using $past
I want to use $past in assertion to check ($past(din != 2’b00,0…2)) // 0,1,2 clocks.The requirement is to check din != 00 for 0,1,2 clocks.how can i use it ?
Something like this i would like to give range - ($past(din != 2’b00,[0:2]))// This is not valid coding style…
($past(din != 2’b00,0)),($past(din != 2’b00,1)),($past(din != 2’b00,2)) My requirement is to merge to range [0:2].
Can i know the correct coding style?
-Regards,
-Raja.
The syntax of the function is:
$past( expression1 [, number_of_ticks] [, expression2] [, clocking_event])
expression1 represents the expression being sought.
You can use the OR or the generate to achieve what you need; of course, that depends on what you need. Those 2 solutions are different.
module past;
	bit clk, a;
	bit[1:0] din;
	initial forever #10 clk=!clk;
   // 	 ($past(din != 2'b00,[0:2]))
     ap_past_or:  assert property (
      	$rose(a) |-> $past(din !=2'b00 , 0)  ||
      	             $past(din !=2'b00 , 1)  ||
      	             $past(din !=2'b00 , 2)   );
   // This will create 3 separate assertions
   generate for (genvar g_i=0; g_i<3; g_i++) begin
      ap_delay_gen:  assert property (
      	$rose(a) |-> $past(din !=2'b00 , g_i));
    endgenerate
     initial begin  // Generation of verification testbench
                    // as described in my new assertion book
     repeat(200) begin
       @(posedge clk);
       if (!randomize(a, din)  with
           { a dist {1'b1:=1, 1'b0:=3};
       		 din dist {1'b1:=1, 1'b0:=2};
       $finish;
  • SystemVerilog Assertions Handbook 4th Edition, 2016 ISBN 978-1518681448
Thank you for the solution.
Now i am using like this,
$past(din !=2’b00 , 0) || $past(din !=2’b00 , 1) || $past(din !=2’b00 , 2)).
I am using on the LHS (antecedent) side. To filter the assertion from triggering.
we can use it right?
Because i see most of the assertions using $past on RHS(Consequent) side.
Kindly let me know on the usage.
once again thanks for the solution.
-Regards,
-Raja.
In reply to sraja:
Syntactically, you can use ($past(din !=2’b00 , 0) || $past(din !=2’b00 , 1) || $past(din !=2’b00 , 2)) as an antecedent since it is a sequence (of length 1 in this case).
However, it is generally odd to see assertions written in this style because it is not expressed in a forward manner. Consider:
($past(din !=2'b00 , 0) ||
 $past(din !=2'b00 , 2)) |-> a;
What is this is expressing? It is saying that “a” is true it is because in the last 2 cycles or in the last cycle or in the current cycle “din” was !=2’b00.
Generally, assertions are written as “cause then effect”, rather than “effect because of cause”. However, what you have is OK.
Yeah I agree with your answer.
Basically,I want a filter.
i.e the assertion should not trigger if the past [0 to 2] clock cycles value is din == 00.
Any ideas or inputs will be helpful to filter assertion.
-Regards,
-Raja.
In reply to sraja:
Am not clear as to what you mean by “the assertion should not trigger if the past [0 to 2] clock cycles value is din == 00.” If I call “a” what I am looking looking for, and that any sequence of 1, 2, or 3 occurrences of (din ==2’b00) means a result of “!a” then you can express it as follows:
 //the assertion should not trigger if the past [0 to 2] clock cycles value is din == 00.
     ap_din_a: assert property((din ==2'b00) [*1:3] |-> !a);
HI ben , I want to write an assertion for a signal “a” and “b” where the signal “a” is the exact replica of signal “b” just one cycle before.
I am implementing this : -
$rose(a) |-> $past(b,1);
Also it is to be noted that the width of both signals are exactly the same.
Correct me If I am wrong here , because I think this sequence is not checking the width of both signals rather ,only posedges of signals with a cycle of one delay.
In reply to prashantk:
$rose(a) |-> $past(b,1); // width of both signals are exactly the same.
  • $rose(a) |-> $past(b,1); is s property and is NOT a sequence
  • $rose(a_4bitbus) means that a_4bitbus went from 4’b0000 to something other than 4’b0000. Thus you would get a rose if a_4bitbus went from 4’b0000 to 4’b0001 or to 4’b1010 or 4’b0100 …
  • When you say $past(b,1), you are saying the in the last cycle “b” was not a zero
  • What you may want is something like
    $changed(a) |-> b==$past(b,1); // if “a” changed, then current “b”== past “b”
    Note the comparitor b==$past(b,1)
Hi ben , Thanks for the explanation.
I didn’t get the second point. As I think $rose() is posedge kind of thing. In your example :-
$rose(a_4bitbus) where a_4bitbus is a 4 bit signal.SO do you mean that anyvalue other than 4’b0000 will satisfy $rose , I mean $rose will take the 4bit bus as single entity and be true , a_4bitbus is changed from 0 to a non zero value.
One more thing : for this four bit bus if value changes from 4’b1100 to 4’b1000 will $rose work here as it is going from value 12 to 8.Please clarify this “a_4bitbus used with $rose”
As you have provided :- $changed(a) |-> b==$past(b,1). But according to this assertion .It implies that whenever a changes(at some ref. clock) , “b” should be 1 one clock cycle before.
But my use case is signal “a” is just a one cycle(of ref clock) delayed version of “b” and nothing else.
First, I was wrong on the following statement
“$rose(a_4bitbus) means that a_4bitbus went from 4’b0000 to something other than 4’b0000. Thus you would get a rose if a_4bitbus went from 4’b0000 to 4’b0001 or to 4’b1010 or 4’b0100 …”
That is in error. after doing the following simulation, it became clear to me that for
**bit[3:0]** a_4bitbus;
**$rose(a_4bitbus) is same as $rose(a_4bitbus[0])**
I should have re-read my book, as in it I state
$rose returns true when the sampled value of a Boolean signal argument transition is true at the current cycle (i.e., least significant bit of the expression==1’b1) and FALSE in the previous cycle (i.e., was 0, X, or Z), with respect to the clock of its context, otherwise it returns FALSE.
My apologies, when I am wrong, I am wrong.
`timescale 1ns/1ns
	bit clk, a, b;
	bit[3:0] data, data_past;
	always_ff  @(posedge clk)  begin
		data_past <= data;
	ap_rose_4bits: assert property(
				($rose(data), $display("@t=%t, data=%b", $time, data)) |-> data[0])
				$display("@t=%t  PASS", $time);  else $display("@t=%t  PAIL", $time);
	ap_change: assert property($changed(data) |-> data_past==$past(data,1))
			$display("@t=%t, ap_change PASS", $time);  else
            $display("@t=%t, ap_change FAIL", $time);
		repeat(200) begin
			@(posedge clk);
			if (!randomize(data)) `uvm_error("MYERR", "This is a randomize error")
				/*if (!randomize(data)  with
					{ data dist {4'b0000:=8, 4'b1001:=1, 4'b0110:=1, 4'b0100:=1};
					}) `uvm_error("MYERR", "This is a randomize error")	*/
		   $stop;
// simulation
 @t=                  30, ap_change PASS
# @t=                  70, ap_change PASS
# @t=                 110  PASS
# @t=                 110, data=0101
# @t=                 110, ap_change PASS
# @t=                 130, ap_change PASS
# @t=                 150, ap_change PASS
# @t=                 170  PASS
# @t=                 170, data=1111
# @t=                 170, ap_change PASS
# @t=                 190, ap_change PASS
# @t=                 230, ap_change PASS
# @t=                 250, ap_change PASS
# @t=                 270, ap_change PASS
# @t=                 290  PASS
For your $past question, here is what I wrote in my book. Hopefully that should answer your questions.
SVA Handbook 4th Edition
“The $past function provides the sampled value that an expression held in a previous nth cycle. The syntax of the function is: [1]
The three optional arguments define the following:
 expression1 and expression2 can be any expression allowed in assertions.
 number_of_ticks specifies the number of clock ticks in the past. number_of_ticks must be one or greater, and must be static (i.e., known at elaboration time). If number_of_ticks is not specified, then it defaults to 1. If the specified clock tick in the past is before the start of simulation, the returned value from the $past function is a value of X.
 expression2 is used as a gating expression for the clocking event. The value returned for $past is expression1 sampled number_of_ticks gated cycles ago. In other words, for:
$past(data, 3, load_enable, @(posedge clk)) the returned value is the sampled value of data in the 3rd prior cycle in which load_enable was true. This is demonstrated in Figure 4.1.1.1-2 /ch4/4.2/past.sv
 clocking_event specifies the clocking event for sampling expression. A clock tick is based on clocking_event.
 Examples: :
regload |=> reg_data==$past(data); // value of load_data at the previous cycle
regload |-> ##2 reg_data==$past(data, 2); // value of load_data at 2 cycles ago
regload |-> ##2 reg_data==$past(data, 2, 1, @(posedge clk)); // value of load_data at 2 cycles ago
regload |-> ##2 reg_data==$past(data, 3, load_enable, @ (posedge clk) );”
One more thing on the $past, To avoid intial potential errors, consider using a ##1 in the antecedent; thus, " ##1 $changed(data) |->$past(…"
A long time ago, when I first learned VHDL, a consultant taught me a simple lesson: Whenever you fail to understand a syntax, run a samll sample program to test your understandings. The likelyhood that the simulation tool understands and implements the language better than you do is very high.
Thanks Ben.
I have a question stating that “If signal a i active then signal b was active somewhere in the past”
someone please help me out in writing the assertion.
how can we pass the ranges to the number of clock ticks in “$past(exp1,number of clockticks,exp2 )” ?
in case of time advancement we have [+]/[*] ? in case of $past how can we achieve that ?
Thanks in advance
In reply to Mechanic:
// ""If signal a i active then signal b was active somewhere in the past"
// This is the wrong way to see or express an assertion.  The recommended approach is the
// forward-looking.  Thus, instead of saying
// BAD STYLE:  If  some_sequence_of_events then some_events must have happened in the past.
// BETTER STYLE:  If some_events then other events now or in the future
// Something like
   b |-> strong(##[1:$] a);
   $rose(b) |-> strong(##[1:$] a);
    Verification Horizons - March 2018 Issue | Verification Academy
  2. SVA: Package for dynamic and range delays and repeats | Verification Academy
You can do something like this.
bit a;
bit b;
bit [N-1:0] arr;
always @(posedge clk)
arr <= { arr[N-2:0], b };
property check_a;
@(posdege clk) (a==1) |-> $countones(arr[N-1:1]) >= 1;
Hi Ben, I was brought here looking for a solution to write something like “did a signal rise in the past”. Just wanted to comment about your suggestion to use forward looking statements. I agree with your comments, but sometimes I want to check the following.
  1. If signal A rises, then signal B rises after 2 cycles. This is obviously easily done with a forward looking statement (rose A implies ##2 rose B).
  2. But at the same time I want to make sure that it was not something else that caused B to rise, i.e. I want to make sure that it was signal A. So I kind of want to check if $rose(B), then looking at the past for 2 cycles, A rose as well.
    Do you think it makes sense to use backwards looking statements (like $rose with $past) in that case, or would you suggest something else to check that?
In reply to Branex:
The simple answer is “maybe makes sense”. The issue is that verification (whether through SVA or other assertion means) checks that the requirements, which tend to be forward looking, are met. Checking that an observed effect is the cause of possible actions in the past can be complex. In critical missions, that is something that maybe useful. Taking the simple case of a traffic light controller, if a RED light occurs, it should be because there was a yellow light previously or because the system just booted. Also, if there is a green light it is because there was a red light before or because the fire dpt turned it on wirelessly and definitely not because it was a boot procedure (assuming at boot you want all the lights to be RED until initialization is done.
Below is a model from a previous post that addresses a technique to do this using support logic. Code is commented and should be self-explanatory.
    timeunit 1ns/100ps;
     bit clk, req, valid, force_on, force_on_ack, ack;
     endclocking
     // 1.when req asserted I should check for valid that needs to be get asserted within 500clocks,
     // then ack should get asserted IN THE NEXT CYCLE.
     ap_req_valid: assert property(@ (posedge clk) $rose(req) |->
                                      first_match(##[1:500] valid) ##1 ack);
    // valid must exist in between req and ack.
    // The following is ILLEGAL
    ap_desired_but_ILLEGAL : assert property(@ (posedge clk)
            rose(valid) |-> $past(1:$, was_a_req));    //
     // Instead, store the fact that a "req" occured. reset when valid
     bit was_a_req;
     always  @(posedge clk) begin
       if(req) was_a_req <= 1'b1;
       if(valid) was_a_req  <= 1'b0;
       ap_valid_req: assert property(@ (posedge clk)
             $rose(valid) |-> was_a_req);
  3. Papers:
