SVA: throughout vs until
I guess I have a fundamental misunderstanding, but I am not sure what it is - I hope someone can clarify.
Consider a property “request req_i must remain high until acknowledge ack_o becomes active, and then request req_i must become inactive”
This can be written a as:
property AP_req_ack0 ;
      $rose(req_i) |-> (req_i throughout ack_o[->1]) ##1 !req_i  ;
   endproperty : AP_req_ack0
There is also the property operator “until_with”. I tried to re-write the above property as
property AP_req_ack ;
      $rose(req_i) |-> req_i until_with ack_o ##1 !req_i ;
However, this doesn’t behave in the same way. The req_i until ack_o seems to work OK, but it doesn’t then check !req_i.
Regards,
Steven
In reply to moogyd:
The until_with is a property operator:
property_expr until_with property_expr
An until property of one of the overlapping forms (i.e., until_with, s_until_with) evaluates to true if property_expr1 evaluates to true at every clock tick beginning with the starting clock tick of the evaluation attempt and continuing until, and including a clock tick at which property_expr2 evaluates to true. Thus, for
You are requiring that the property (which is a sequence in this case, but a sequence can be a property)req_i==1 until the property (ack_o[->1]) ##1 !req_i) completes. Thus, you are requiring that req_i==1 when it completes AND also in that SAME last cycle req_i==0. Sorry,but that ain’t going to happen!!!
The req_i until ack_o seems to work OK because in the last cycle there is no test for req_i.
An until property of the non-overlapping form (i.e., until, s_until) evaluates to true if property_expr1 evaluates to true at every clock tick beginning with the starting clock tick of the evaluation attempt and continuing until at least one tick before a clock tick where property_expr2 (called the terminating property) evaluates to true
Hi Ben,
Actually, the throughout version behaves as I expect (and wanted).
For the throughout property example, I explicitely added the parentheses to ensure the correct behaviour - I already came across this “gotcha”
// Need to be careful with () here. It seems that the "##1" may have higher precendence than the "throughout"
So the req_i througout only applies to ack_o[->1]
I am still not sure about the until_with version.
Basically, it works (i.e reports a failure) if the req_i becomes inactive before the ack_o becomes active (the until_with part).
However, if I change the stimulus such that the req_i stays high after ack_o, the “throughout” version correctly reports a failure, but the “until_with” version does not, which implies it is not “moving on” to the !req_i check.
At some point in your email, you state that:
You are requiring that the property (which is a sequence in this case, but a sequence can be a property)…
Is the converse true? i.e. is it correct to treat
as a sequence? If not, I guess using the ##1 is invalid in this case?
One interesting thing I noticed is that if I try to add parantheses to the property
   property AP_req_ack1 ;
     $rose(req_i) |-> (req_i until_with ack_o) ##1 !req_i ;
   endproperty : AP_req_ack1
I get complilation error. With Aldex Riviera Pro (EDA playground)
ERROR VCP2000 “Syntax error. Unexpected token: ##[O_HASHHASH]. Expected tokens: ‘;’.” “testbench.sv” 69 48
FAILURE “Compile failure 1 Errors 0 Warnings Analysis time: 0[s].”
Exit code expected: 0, received: 1
(Also checked the incisive)
Again, this implies that there is some fundamental difference between the throughout and until_with operators
Steven
In reply to moogyd:
// Need to be careful with () here. It seems that the "##1" may have higher precedence than the "throughout"
You are correct about the precedence rules. From my book, I am showing below those rules:
1800 says: An until property of one of the overlapping forms (i.e., until_with, s_until_with) evaluates to true if property_expr1 evaluates to true at every clock tick beginning with the starting clock tick of the evaluation attempt and continuing until, and including a clock tick at which property_expr2 evaluates to true.
Thus, if property_expr1 evaluates to false (your req_i) then the property expression with the until_with fails. However, if req_i stays high after ack_o, I would have expected a failure. Can you share the test code?
The converse is NOT true. If you look at the BNF for a property you’ll see
property_expr ::=
     sequence_expr
  | strong ( sequence_expr )
  | weak ( sequence_expr )
  | ( property_expr )....
But the BNF for a sequence does NOT show a sequence as a property as a possibility.
Actually, that makes sense because of the hierarchy of operators: sequences are built out of expressions (a sequence of 1 terms is the expression). Properties are built out of sequences. Concurrent assertions are built out of properties.
One interesting thing I noticed is that if I try to add parentheses to the property
The simulation tools are correct, you cannot concatenate a property with a sequence. The (req_i until_with ack_o) is a property. However, you can concatenate a sequence with a property with the followed-by operators
 property_expr ::= // among other things
  sequence_expr #-# property_expr
| sequence_expr #=# property_expr
Hi Ben,
My test code is available on EDA playground throughout_vs_until_with.
Steven
In reply to moogyd:
consider the code at Edit code - EDA Playground
ap_untilw: assert property(
	$rose(a) |-> b until_with c ##1 !b)
	 $display("ap_untilw passed, b=%b at %t", $sampled(b), $time);
	ap_until_eq: assert property($rose(a) |-> b[*1:$] ##0 c ##1 !b) ; // equivalent assertion
b must hold only at the beginning of c ##1 !b, i.e., the moment of the truth of the property c ##1 !b. Thus the property expression 2 when it completes i
(b && c ##1 !b).
Thanks a lot Ben!
The observed behavior makes more sense now. Although it also shows that I only have quite a superficial understanding of SVA :-(
Steven
p.s. Just out of interest, the example https://www.edaplayground.com/x/39YH behaves differently with Incisive and Riviera Pro. There are different messages in the log.
In reply to moogyd:
Thanks a lot Ben!
Steven
The different messages is because Riviera displays all messages, vacuous and non-vacuous, whereas Incisive displays only the non-vacuous passes. There should be a switch for Riviera to suppress the vacuous pass action blocks.
In the above example, there is no clock referred for the property. Will it not get any compilation issue?
In reply to Anudeep J:
You either need to add a clocking event or use a default clocking.
// what I usually use
//override the default
ap_untilw: assert property(@(posedge clk2)
Ben systemverilog.us
